spacers for rod ends
Old 05-10-2014, 09:57 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
I'm in the ordering stage of making my own rear lower control arms out of 1 1/8th" aluminum tubing and QA1 rod ends. I know I'm going to need bushings for the rod ends to work with the stock bolts but what width spacers would I need for the rod ends?
Old 05-10-2014, 10:03 PM
Alice89's Avatar
Re: spacers for rod ends
http://www.jonaadland.com/Z28/Mods/L...minumLCAs.html
1" OD x 3/4"
I built ones very similar to the ones in the link above for my old 4th gen... I still have them. They have held up good! Just FYI.
Old 05-10-2014, 10:13 PM
lb9 GTA's Avatar
Thank you NOSHOWALLGO. Since you've built them befor what length tubing did you go with. I was thinking 16" but a guy I work with who races modified circle track thinks 15" would work better.
Old 05-10-2014, 10:37 PM
Alice89's Avatar
I personally would just stick with 16" trailing arms. Thats the length I'm using. At that length you will have more than enough adjustment without running into thread pull-out issues. (You can adjust them from 19" to just over 20")
customblackbird
08-15-2021 10:16 PM
Amillionoh7
05-24-2020 08:01 AM
gixxer92
09-01-2015 04:32 PM
zayne0
08-24-2015 07:22 PM
Quick Reply: spacers for rod ends
