Recommended Shocks and Struts
Old 10-07-2014, 07:49 PM
87firebirdgta's Avatar
Car: 1987 Pontiac Firebird Trans Am GTA
Engine: 350 small block, Carbureted
Transmission: 5-speed manual
I have a 1987 Trans Am GTA and I am in need of new shocks and struts. I would like them to perform well on the street and drag strip. Does any one have any good recommendations?
Old 10-09-2014, 05:24 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Recommended Shocks and Struts
Old 10-12-2014, 01:19 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
How much do you want to spend and what do you want out of the car?
Old 10-12-2014, 10:23 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Define perform well: if your looking for a corner carver on the street that can be a wheel stander at the track at the same time it's not going to happen. You kind of have to settle for superb street handling and spinning at the track or dead hooking at the track while slowing it down on corners. Or settle for average on both as middle ground.
Old 10-13-2014, 05:29 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Koni now makes an affordable entry level set up called STR.Ts $400, I believe pronounced streets, just picked up a set for my 96, have not installed, I have kybs on my daily driven 84, they work fine, nothing special, though
Old 10-13-2014, 12:27 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Have your exact car. I upgraded years ago to Moog springs and KYB struts/shocks. Had them for years and just grew unhappy with that setup. Did my research and replaced that with Eibach and Bilstein setup, had them for about 8 years now. Very happy!!
Old 10-20-2014, 07:26 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
@Buddy - which Bilstein shocks did you get?
How would you describe the ride?
Old 10-20-2014, 06:39 PM
Buddy's Avatar
I went with the Eibach Pro kit and HD Bilsteins. Pro kit is a 1' drop, so perfect, Sportlines are too much of a drop for my liking and the ride gets harsher. Any setup in our cars is going to be tight and firm, but I found this setup to be near the top in terms of a "smooth" ride, while keeping handling amazing. It's a bit pricey, but once it's done your done forever, I spent more $ going through different setups, so I suppose I spent more LOL. I got mine at shox.com, was the cheapest price around at that time.
Old 10-21-2014, 02:38 AM
peterc005's Avatar
Transmission: T700
@Buddy you mean the B6 HD, not the B8 SP?
I'm still trying to figure out the difference, I thought the SP were designed for lowered suspension and would be better with the Eibach springs?.
Old 10-21-2014, 01:18 PM
Buddy's Avatar
Bilstein only makes 1 strut for the front, but 2 shocks for the rear, HD and Sport. The Sport is just slightly firmer. I went with the HD and don't think I would want the Sport, HD is perfect. I am lowered 1". I seem to recall something about the Sports and 2" lowering (Eibach Sportlines), but either shock will work on your car.
Old 10-21-2014, 06:58 PM
peterc005's Avatar
Transmission: T700
It's hard to figure out, and the Bilstein website is useless.
Summit seem to offer a SP front strut for third gens, but not the HD version:
http://www.summitracing.com/int/part...t/model/camaro
I read somewhere that the HD and SP had the valveing, but that the SP was for lowered cars which would suit me as I have Eibach Proline springs.
Did you Bilstein HDs lift the car ride height?
I'll probably just go with the Bilstein HD, a lot of people seem to recommend them with Eibach springs.
Old 10-21-2014, 08:36 PM
Buddy's Avatar
Also try shox.com, they have both. The shocks/struts didn't seem to lift my car much.... I put the Eibachs on at the same time, so my car came out lower than stock after.
Old 10-21-2014, 08:58 PM
peterc005's Avatar
Transmission: T700
Buddy, seems you are right, only Bilstein HD available for the front struts.
I'll get a set of front/rear Bilstein HD.
Old 10-21-2014, 10:10 PM
Buddy's Avatar
If you go on shox.com, you have to look them up under 82-92 Chevy Camaro. It will come up Camaro/Firebird.
You will be happy with the HD's and Eibach Pro kit. Bilstein and Koni are both top notch shocks/struts, great quality and R&D in them. You'll see when they are in your hand.
Pac J
05-17-2020 10:44 AM
Ed1LE
09-30-2018 09:14 AM
LT1Formula
10-08-2015 08:34 PM
loud91rs
10-05-2015 10:05 PM
meeklay812
10-01-2015 03:46 PM
Quick Reply: Recommended Shocks and Struts
