rack and pinion conversion in 89 camaro
Car: 1989 IROC
Engine: 6.0L Twin GTK450
I am curious if anyone has done this swap in their 3rd gen. I am currently working on my 89 IROC with a LS sway, I have a UMI K-member. I've heard a lot people talk about the Mustang and 4th gen racks, would any of these work with fabrication?
Engine: 4++,350 & 305 CIs
Re: rack and pinion conversion in 89 camaro
Been done. Do a quick search, many topics about it and the limits it brings.
Car: 1989 IROC
I've searched but all I find is manual rack conversion, not power
Most just go manual for drag racing. Power rack would be the same but you have to hook up the psi and return line.
Car: 1989 IROC
Gotya, is there any way that i would be able to use the 4th gen camaro rack?
I think the info is in the threads.
maybe if you have it narrowed and rethreaded
Remember, your turning radius will not be as good
Car: 1989 IROC
appreciate the info man!!
might have to leave this one for the shop though!
I don't think anyone has found a good solution to fix the reduced turning radius yet.
Car: 1989 IROC
I've heard guys saying that a 6" radius would be good, whats your take
1 Post
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Available travel is the first issue with a lot of racks, reducing your turning radius. Our steering arms are ~7" long compared to ~5" in a lot of other cars so it takes more steering travel to move the wheels.
The next issue is bump-steer issues caused by center to center width on most racks. The stock center link is like 15.5" between tie rod centers. You want the tie rods to be close to the same length as the LCA. The greater the discrepancy, the more severe bump-steer issues you'll have. For this I'd suggest using circle track rack racing rack and pinions. For drag racing you can get manual versions as well.
I've been looking into this, but I'll probably run out of time/funds this winter to complete it. I've got an ebay used 18.25" center to center rack I'd like to try.
This topic has caused some very dramatic conversation on these boards. There are some that say it can be done (but haven't done it) and other's that say it's impossible to do it right.
I've researched it pretty heavily before giving up and rebuilding my recirculating ball setup with all new hardware.
The issues, as stated earlier, are turning radius and bump steer. You need a rack that has 7 to 8 inches of travel, but is narrow enough that you can have tie rods as long as your current setup. A center takeoff rack solves the second problem, but I haven't found anyone that makes a rack with that much travel. A modified spindle could solve the travel problem by reducing the length of the steering arm, but no too many people are willing to mess with this.
When looking at other racks to try, make sure you get a front steer (the steering knuckle is forward of the spindle) instead of a rear steer (the steering knuckle if aft of the spindle).
If you solve both problems, let us know because there is a lot of interes.
Terrell351
06-13-2021 01:13 PM
Thomas
Exterior Parts for Sale
21
10-07-2015 05:33 PM
Thomas
10-03-2015 05:34 PM
hectre13
08-26-2015 08:17 AM
