Heim Joint Steering
Car: 1986 Trans Am
Axle/Gears: 3.08? unlimited slip
Heim Joint Steering
I've been noticing that a lot of the off road racing trucks use heim joints on the ends of their tie rods. I was just wondering if, say on a race car, would it be beneficial to fabricate a steering system that used all heim joints (for center link, tie rod ends) instead of regular tie rod ends? It seemed like an interesting thought to me.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Heim Joint Steering
The tie rod ends at the spindles are rod ends with spacers to correct for bump steer. It's all part of a kit. The center link, idler arm and inner tie rod ends are still OEM. The ball sockets in all the other components work just fine. Converting the entire system to use rod ends is possible but the only advantage to doing so is for cleanliness.
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
I've seen a few of the autoX/RR guys with them for bump steer. Can't remember which ones for sure, but Pablo is one (also has custom fabbed steering knuckles to clear his 17x11's, info for that is on frrax), maybe BIG_MODS but not sure. Also search slicktrackgod or vetruck, same guy, but i think he had them too. All 3 are very awesome track cars.
Engine: 4++,350 & 305 CIs
Its been done for years.
sjorgens
10-01-2015 07:54 PM
