6 lug square body?
Car: 1990 c1500
Engine: 357 chevy tbi
Transmission: Built 700r4
6 lug square body?
So ik this is for third gen stuff but i drive a tbi truck and you guys know alot about the too. Anyway my neighbor had a square body 80s era chevy truck its only good as a parts trck and he may let me buy the rearend and motor out of it for a future project but i would want to put the rearend in my 90 truck. My question is how do i determin the readend ratio? Where is the pro code in my truck its in the glove box but this one seemed to not be there i looked and it had a blue sticker with no codes on it and its a 4x4 and the trearend was 6 lug so whats up with that? I don't know much about a 6 lug rearend. Any ideas?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 6 lug square body?
6 bolt axles is normally referred to as a heavy half. Still a half ton suspension. Probably just a 8.5" 10 bolt diff. Might be a Dana.
Try doing some research on truck forums that cater to 80's GM pickups since this has nothing to do with third gens.
Car: 88 5.7 Iroc
1/2 ton 4 X 4 Square bodys came with 6 lug axles all the way from 74 to 87. 80's model trucks came with what was referred to as a corporate 10 bolt. Not quite as strong as a 12 bolt, but stronger than a passenger car 10 bolt. 2WD trucks had 5 lug axles.
Axle ratios can determined buy rotating axle one revolution and count pinion yoke revolutions. Not exact, but will get you in the ballpark.
Car: 1990 c1500
Car: 91 Firebird
Engine: 6.0
you could prolly just swap your 5 lug axles into that housing to make it work
the RPO codes are all the same in regards to gear ratios, no matter if it was in a truck, wagon or corvette.
So look at the rpo codes and start googling them. Here is a quick list I found on fullsizechevy.com
GT4 -- AXLE REAR, 3.73 RATIO
GT5 -- AXLE REAR, 4.10 RATIO
GU4 -- AXLE REAR, 3.08 RATIO
GU5 -- AXLE REAR, 3.23 RATIO
GU6 -- AXLE REAR, 3.42 RATIO
G80 -- AXLE REAR, LIMITED SLIP (POSITRACTION)
HC4 -- AXLE REAR, 4.56 RATIO
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Car: 1990 c1500
Well the truck looks stock and the owners told me theres never neen any major work done too it so i expect the rearend to be untouched.
Car: 1990 c1500
Car: 91 Firebird
Engine: 6.0
You *might* get away with that.....
but you would have to pull the axles to find out. At some point, GM switched from 26 spline axles to 28 spline, which I *think* was 87/88 in the fbody. Not certain about the trucks though
and yes, someone could have swapped the rear. Knowing the codes is just some knowledge. If you walk up and it has a code for a non posi 2.73 rear, I would walk away.....
Car: 1990 c1500
1 Post
You could try to look up the VIN, that would get you the RPO codes.
Hotrodboba400
12-10-2019 07:07 PM
Kenwood
09-04-2015 05:50 PM
