founders camber caster plates
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
hey guys looking for people who have used the founders caster camber plates. doing an entire front end rebuild this winter complete with struts and want to replace the strut mounts while im there. since I can get the founders pieces for about 50 bucks more then stock replacement strut mounts im kinda looking at them.
just looking for people who have used them. they a good piece and hold up well over time. ive done a search and only found people that had just got them. any input would be nice.
thanks.
thanks.
Car: 84 Camaro Z28
Engine: 355 Carb
Re: founders camber caster plates
Im currently running them on my camaro and absolutely love them
They are better then the rubber bushing stock set up it came with. .
I road race and autocross with the founder plates and they have held up plenty well to the abuse i have given them
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I dropped my car out of the air, and they held up. So I'd say the are made with thick enough material.
Engine: 383
Yeah not worried about the dust covers.I'd have to take them off to adjust my new struts any way. That being said it sounds like the are a good solid product and I shall give them a try.
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
IIRC, J&M Products/Hotpart.com CC plates and Founders CC plates housings are made by the same third party. Recently Founders upgraded the bearing material. For this reason and the lower price of Founders, I would buy the Founders.
A couple years ago I bought J&M Products and they work great. No issues. I definitely put it to them in autoX and they hold up without issues. I always tighten them with a torque wrench when changing from street to track set up and vice versa.
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
I am in the process of installing these along with new struts. I came across a hiccup in the install as it turned out by accident they sent me the wrong hardware kit. I called them late last night, left a voicemail message and received a return call today. The correct hardware is on its way to me. The overall quality of the kit appears to be good. I overhauled the rear suspension this past summer and used a bunch of their parts and am very happy with them.
I'm also thinking about buying these. I'm keeping my car stock rubber where I can, so I wonder, if these aren't rubber anymore, will there be an impact like more stiffness as other than rubber bushings can cause in LCAs or sway bar bushings and end-links?
Engine: LB9 | LS1
I recommend them. Build quality is very good.
No rubber? Hm... it's just... @Blackmamba mentioned "...they are better than the rubber bushing stock setup it came with...". So I thought that the OEM ones had rubber somewhere... ??
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
As long as your struts aren't worn out, you'll have no problem. This is what gives them the crisper suspension movement.
Engine: 383
Brand new kyb agx struts at the same time. Should be good there to .
morrow
01-13-2024 12:29 PM
monte87cortez
09-26-2015 08:10 PM
