Sway bar.
Car: 92 camaro/99 gmc Z71
Engine: 357/5.3
Transmission: built 700r4 4500 stall/4l60
Axle/Gears: 4.56/?
Sway bar.
What are the benefits of removing the front sway bar? I have heard it is better for drag racing. Benefits or no benefits?
1 Post
Car: 1991 firebird GTA
Engine: 305 tpi
Transmission: 5spd
Axle/Gears: 3.42 posi
Re: Sway bar.
It helps with weight transfer which in turn should help with traction. But if this car is gonna be driven anywhere off the track, it's suicide.
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Sway bar.
Yes, it's a drag racing trick. Removing it allows the front to lift more helping weight transfer. If you drive like a grandma you could get away with not having one. I wouldn't corner without one.
camaro1185
10-26-2015 06:51 AM
darwinprice
17
10-11-2015 11:51 PM
