drop spindles...I think I found 'em
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
check it out
http://www.airbagit.com/spindles-ste...ontiac8286.htm anyone used them or heard from them I have been searching the internet for weeks looking for some even the recommendations I found on here seemed to have stopped making them. I really want to lower my car but I think 2" might be too much but at this point I will take what I can get. so pretty much anyone ever use em?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: drop spindles...I think I found 'em
They are not the right knuckles
Engine: 4++,350 & 305 CIs
Could be a file photo. Maybe a phone call or email.
does anyone know where to get ones that work?
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
check it out
Engine: 350 ci
thank you for your interest but the parts have been sold.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the link is for G body spindles, listed as LeMans spindles...
why get lowering spindles when extended balljoints and chopped springs gets you to the same place a lot cheaper?
Engine: 350 ci
yeah, let me pick them up at the extended ball joint and chopped springs store. Cheaper?
There's alot of info on here about how drop spindles help lower the CG while keeping the front RC high up which is a good thing on a front heavy car.. There are pros and cons but if someone designed a strong enough 2" drop spindle for the street, it would be worth the $$$ IMO.
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Yes, pricey. I paid $550 or so, then found out I didn't receive the RoadRace beefy version that I requested. Sent 'em back in, another $150 or so, another alignment. I won't give 'em up, and Racecraft no longer offers them.
I am curious on image 6, it appears the two center holes have incomplete threads. This usually happens when the wrong size tap drill is used. It appears the tap drill used was too large netting this condition. Incomplete threads are very easy to strip out when tightening. FYI....the pieces look fantastic and the welding is excellent.
Ghettobird52
12-29-2023 08:23 AM
92camaroJoe
08-13-2015 06:07 AM
