Crossmember Triangle Brace Bolt Size
Car: 1986 Chevy Camaro Berlinetta
Engine: 305 V8 5.0 carb.
Transmission: Automatic
Axle/Gears: the kind that came with the car...
Does anyone know the exact size to the bolts that hold the Crossmember Triangle Braces onto the Drivers side and Passenger side on a 86 camaro.
I located the braces but no luck on the bolts. I just need to know the correct size of these bolts. Thanks
Received 1,666 Likes
Re: Crossmember Triangle Brace Bolt Size
If memory serves they were 8mm (13mm head) body type bolts; pointy ended.
toronto formula
11-10-2015 06:17 AM
1Aauto
Sponsored Vendors
08-26-2015 02:18 PM
knight72
08-10-2015 09:32 PM
