Steering shaft upgrade
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
Ok so im looking at a 1980's chevy g20 van and i see that it has the u joint steering shaft just like the one in the astro vans im wondering if this will work in my 88 gta also if it will fit what meeds to be done for it to fit into a f body i remembering reading something about the u joint needs to be spun 90 degrees in order for it to keep the steering in alignment is this true
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Steering shaft upgrade
There are many threads on this and members selling the components all ready to install. Do some searches.
1 Post
Ok so instead of the astro van shaft i decided im gonna use the xj cherokee shaft we have 2 of them going to scrap at work and my boss said if u need anything pull it out now before it goes i saw that this is a direct bolt in is this true or is there major work involved
I think the Jeep shaft requires you to grind a groove in the end of the steering shaft that comes out of the fire wall.
I cant help with your last post as I have no experience with the jeep shafts...
But I did buy a astro shaft from member "MC87SS" and had no issues what so ever with the transaction. The astro shaft he sold me made a noticeable difference, even with a brand new rag joint my steering still had a small amount of play. Installing the astro shaft completely eliminated the last of the play I had in my steering.
Here is his for sale thread:
https://www.thirdgen.org/forums/engi...t-upgrade.html
Maybe try messaging him if your interested... Hope this helps.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Yes it does. I have a jeep shaft in my camaro, and I had to grind a small groove in order to get the retaining bolt to fit. Not a difficult job, took only a few minutes with my dremel and a grinding stone.
1 Post
Yea i wanted to do the astro shaft but if i can get the jeep shaft for free im gonna go that route im how ever gonna be the astro van steering column bearing to also eliminate the factory f body plastic one we have a astro van thats gonna be going to junk as well soon so ill make sure to take the steering shaft and bearing off that just to have the shaft as a extra and install the steering column bearing to have it installed in my steering column i have for my car
1 Post
And if u dont mind can u send a pic of what i need to grind that would be great u can send them to my email soarestransam@aol.com
Car: 1992 Camaro RS
1 Post
Ok thanks alot for the help
https://video.search.yahoo.com/video...&fr=aaplw&tt=b
Here's a how-to I contributed a while back:
https://www.thirdgen.org/forums/susp...ing-shaft.html
JamesC
JamesC
1 Post
Hey james thanks for contributing to the thread im going with the xj shaft instead though since its more user bolt in i seen a vid of it where u heat it up but the grinding part im trying to figure out what needs to be grinded down
JamesC
1 Post
Ok when i get the steering shaft home ill see where it needs to be grinded at to make it fit
Car: 1992 Camaro RS
Grabbed a few pics today of my setup. You need to grind the shaft right under where the bolt is sitting.
1 Post
Ok so this is on the steering column im guessing not the steering box side
1 Post
Ok so i got the steering shaft out yesterday and it got it installed on the column now will this keep the steering wheel straight when i install it onto the steering box or am i gonna have to recenter the steering wheel
Car: check
Engine: check
Transmission: check
Note that it isn't unusual for the steering wheel to be off a little after replacing anything in the steering column linkage.
RBob.
Car: 85 & 87 Monte Carlo SS/80 El Camino
Engine: 305/350/454
Transmission: 2004R, 2004R, TH400
Axle/Gears: 3:42, 3:73, 3:23
The 2nd post has instructions on notching the column.
https://www.thirdgen.org/forums/engi...ing-shaft.html
dbrochard
10-03-2015 12:43 PM
rb85TA
26
09-14-2015 10:29 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
