Steering wheel moves but tires don't
Car: 1991 Camaro RS
Engine: 5.0
Okay I'll try to explain what happened.
So my problem from jump was I can turn my steering wheel left all the way with no problem but when turning right it wouldn't go all the way so I had to make right wide turns all the time.
Just a couple days ago I jump in my car put it in reverse start turning the steering wheel and hear a loud pop and found two broken bolts under the vehicle. Tried turning the wheels and they wouldn't move just the steering wheel moved. I was told that there should of been three bolts connected not two. What could be my problem
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Steering wheel moves but tires don't
should be really easy to tell what came apart just by looking at it..
Trace your steering shaft, look for what's broken. A simple check under the car should reveal your problem.
When you say "I had to make wide right turns all the time" do you mean that you've been driving the car in this condition for a significant time?
Car: 1991 Camaro RS
Engine: 5.0
Maybe about a week but sometimes it allowed me to make full turns with the steering wheel to the right and sometimes it didn't but I believe it's the steering box to frame bolts that broke
Car: 1991 Camaro RS
Engine: 5.0
Car: 1991 Camaro RS
Engine: 5.0
Without more info I can't say for sure. if the bolts were from the steering box then:
A-something stopped moving (in the box? in the shaft?)
B-It was so locked up that it had enough torque to sheer the bolts to the steering box off
Locate whatever it is that doesn't want to move, that's what you'll be replacing lol.
Car: 1991 Camaro RS
Engine: 5.0
Car: 86 Camaro
take pictures of the steering box and the steering linkage under the car and post them up... this is not something to screw around with: your life and the lives of everyone on the road with you could depend on fixing this right..
Car: 1991 Camaro RS
Engine: 5.0
Trust me I'm happy I wasn't driving at the time it actually happened, I will definitely take some pictures a little later and post them up, I've had the car sitting ever since it happened
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Sounds like the rag joint is torn into.
The plastic cover with the bulge in it is covering it, side it back and look.
Car: 1991 Camaro RS
Engine: 5.0
backtothe80s
09-05-2015 12:39 AM
