Rear Sway Bar Size?
Car: 1989 Chevrolet Camaro IROC-Z/Z28
Engine: 5.7L/350 cu. in. V8
Axle/Gears: Borg Warner 9 bolt 2.77 posi
Rear Sway Bar Size?
I have a 1989 Camaro IROC-Z and want to redo the bushings on the stock rear sway bar with Energy Suspension polyurethane bushings. The auto parts store I went to didn't know what size rear sway bar I have and neither do I. What is the the stock rear sway bar size on my car? 20mm?
Car: 1988 Camaro
Re: Rear Sway Bar Size?
I am not sure, but you can measure yours with a dial caliper if you have one.. If you do not have one then you can use an adjustable wrench or open end wrench set
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
