engry suspension bump stops. from orileys
Car: 89 iroc
Transmission: t5
Axle/Gears: 323
So some things happened and stuff happen that involves a sawzall, paint thinner, and a torch to burn out some old bushings. Well I may or may not have accidentally lit the bump stops on fire lol. (Not a huge deal because we were changing them anyway just not right away. So I want to start putting the front end back together tomorrow. So can order the stops from summit but I was wondering if these would work since the entire suspension is getting converted to polyurethaneanyway. I used the search but I didn't find anything that answered my question http://m.oreillyauto.com/mt/www.orei...0958&ppt=C0361 so would these work
Re: engry suspension bump stops. from orileys
The GM type poly stop can be purchased from Summit (ENS-9-9150R, the "R" is for red) as you probably know. That said, many members would say to avoid poly for the stops as there is no 'cushioning' effect. Also, bumps stops come in two sizes:
https://www.thirdgen.org/forums/susp...s-created.html
JamesC
JamesC
Car: 89 iroc
Transmission: t5
Axle/Gears: 323
I already have the rear of the bushings I went and got the energy suspension master kit. The only thing I'm missing is the away bar bushings (because there are three different sizes apparently) and a trans mount which I'm also going to buy today. I did have 16" snowflakes but they are gone now in favour of a skinny fatty setup which are 15" rally wheels. But I guess if those won't work i will have to hunt around auto part stores and see if I can find them. I'm on a major time crunch so if they half to be ordered rubber or polyurethane I won't have a choice I'll have to throw the cracked ones bback in until the new ones come. Lol I was just hoping because they were $13 and plentiful
Before you purchase, you might take a look at the following link:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
JamesC
Car: 89 iroc
Transmission: t5
Axle/Gears: 323
JamesC
JamesC
LT1Formula
10-08-2015 08:34 PM
