Vogtland Spring Install
Old 09-14-2015, 09:18 PM
87v6Bird's Avatar
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
Hi guys. Thought I'd share the results of my spring install over the weekend.
When I did the engine swap on my car a few years ago I went with new Moog springs front and back. I had 5660s up front and 5665s in the rear. I had put a little more than 20K miles on them but I finally decided my car was just riding too high with them.
I measured fender height on the driver's side before and after the swap. Here are my results:
Front Rear
Before 27.5" 28.5"
After 26.75" 27.25"
200mi 26.5" 27.25"
3 Months 26.25" 26.75"
1 Year 26.25" 26.625"
2.75 Years 26.125" 26.25"
For reference, I'm running 275/40R17 BFG Sport Comp 2 tires. I'll try to remember to update this as I put more miles on them to see if they settle more.
Before pictures:
Profile
Front Measurement
Rear Measurement
After Pictures:
Profile (Sorry this picture is rotated. Photobucket is not cooperating.)
Front Measurement
Last edited by 87v6Bird; 07-01-2018 at 04:09 PM. Reason: Updated Results. Corrected Moog front springs.
Old 09-15-2015, 09:31 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Re: Vogtland Spring Install
Thanks for posting... Subscribed
Old 09-24-2015, 07:37 PM
87v6Bird's Avatar
Engine: 406, LB9
Update after driving for the week. The front has settled another 1/4". Now I'm at 26.5" front/27.25" rear.
Old 12-17-2015, 10:10 AM
ctoledo0834's Avatar
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
How's the ride quality ?
Engine: 350 carb
In between these and the sportlines
Old 12-20-2015, 07:48 AM
87v6Bird's Avatar
Engine: 406, LB9
I've never had sportlines to compare to. My springs were stock replacements.
When I installed these I also went from a set of Monroe shocks/struts to Koni yellows so I have a hard time drawing conclusions on what the springs changed. To me, the front feel softer while the rear is harder but that could just mean I need to tweak the adjustments on the shocks. That's something I intend to do, I just haven't gotten to it yet.
Old 12-20-2015, 07:51 AM
87v6Bird's Avatar
Engine: 406, LB9
I updated the settling results in the first post as well.
Old 12-21-2015, 03:06 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Does it ride stiffer than the MOOG springs?
Old 12-22-2015, 06:48 AM
87v6Bird's Avatar
Engine: 406, LB9
It's seems to me like the fronts are softer than the 5660s while the rears are stiffer than the 5665s. It could be that my rear shocks are set too stiff though. I haven't had time to tweak their settings and compare.
Old 03-11-2016, 03:03 PM
87v6Bird's Avatar
Engine: 406, LB9
I finally got a chance and backed off on the rear Koni's adjustments and the car rides much better now. I would say the ride is still a little stiffer than stock but nowhere near the jarring experience it was prior to adjustment.
I need to get the 89 TA rolling again and I'll be able to compare because it has the shocks and springs that came off this car.
Old 09-17-2016, 08:53 AM
87v6Bird's Avatar
Engine: 406, LB9
Revisiting this since I answered it in another thread as well. I stand by my feeling that the Vogtlands may be a little softer in the front while stiffer in the rear even after shock adjustments. The picture shows what I'm comparing and gives some tire/ride height measurements as well.
Old 09-17-2016, 10:06 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: supercharged 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I just installed some used vogtlands today. What a PITA. I didn't use a spring compressor either.
I'm not sure what happened but the rear spring I had to compress by doing a bench press with it in the pocket (I'm very strong lol) and I was able to get it in. But I'm not sure if it's due to my Viking double adjustable rear shocks not having as much travel as an OEM type shock? By my rear was at full drop with the shocks holding it up. This was without the OEM rear spring isolator. No way I would be able to get it in with that on. So I just used some heater hose.
Fronts were even worse to get in but eventually figured it out without a compressor as the one I had wouldn't fit. Sitting pretty low now esp in the rear. It dropped 1.5-1.75" over what I had and it hasn't even been driven yet.
I'm more interested in the driving habits. This is a huge drop in spring rate for me in the front. I was running 800lb front springs on weight jacks and 150lb rears on jacks. I wanted a more comfortable ride than what I had as I only drive the car on the street now.
How would you say it handles? Bumps and holes obnoxious? Rough? Body roll? I figure it can't handle better as the fronts are less rate than stock. I'm glad the rears are stiffer as I always felt OEM was soft.
Old 09-17-2016, 10:46 PM
87v6Bird's Avatar
Engine: 406, LB9
If I remember correctly, the Vogtlands were actually taller uncompressed than the stock rear springs. I'm pretty sure I put mine in before I bolted up my shocks. I used the factory spring isolators.
Comparing my two cars, the 87 (Vogtlands) definitely handles better and handles better than before it was lowered. I think the biggest factor in the handling is the much taller sidewalls on the 89 (Moog). I do think body roll in the front may have increased on the 87 when I went to the Vogtlands. I have a set of WS6 sway bars I intend to install to see how they affect things. Bumps (especially train tracks) are more jarring in the 87 but I expect that since everything in its suspension has less give. I hesitate to attribute the ride harshness solely to the springs.
Old 09-18-2016, 10:17 AM
Car: 87 TA clone
Gotcha. Yea not a fan of removing the rear shocks. Not very fun with a 8pt roll bar in the way. I understand some tension to keep the spring in the pocket when the suspension is fully unloaded but without the isolators it's still a good bit of tension so with the stock isolators it's even more. I'm pretty low in the back or it appears to be due to the 18" rim and 40 sidewall.
Old 09-18-2016, 11:17 AM
Car: 87 TA clone
Just took mine for a 15min drive and tried to get the suspension to settle.
Loving the springs thus far. Handling is def softer than the 800lb fronts and doesn't feel sloppy although u can feel they are softer I think for a DD car they are very nice. The rear of these cars needs more than stock spring rate and thus very happy with ride equality and response. I have my front AGX struts on the 2nd setting (1-4) so soft/med and the rear Vikings are on a soft street setting. Since I run 18" rims and a 275/40/18 tire I'm taller than stock which prob attributes to my 27.5" front fender height and 27 5/8" rear fender height. The rear springs dropped it 1.5" over what I had in it. Front is slightly lower if not the same as the 800lbwhich is fine as I wasn't scrapping on anything.
Old 07-01-2018, 04:12 PM
87v6Bird's Avatar
Engine: 406, LB9
Updated heights.
sailtexas186548
08-26-2015 03:32 PM
TheExaminer
08-25-2015 07:34 PM
crazynights
08-21-2015 06:53 AM
1988iroc350tpi
08-14-2015 07:52 PM
Quick Reply: Vogtland Spring Install
