Bump steer kit required for 1" lowering? What's your results?
Car: 90 Formula / T-tops
Transmission: MD8
Are you guys finding a bump steer kit is needed when lowering your car 1" using lowering coil springs?
Transmission: MD8
Re: Bump steer kit required for 1" lowering? What's your results?
Found some old threads where people are discussing this issue.
https://www.thirdgen.org/forums/susp...ll-center.html
https://www.thirdgen.org/forums/susp...ints-good.html
Clearance concerns with extended ball joints
https://www.thirdgen.org/forums/susp...clearance.html
First hand account:
https://www.thirdgen.org/forums/susp...ml#post5154883
First hand account:
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Lowering springs doesn't change the relationship between the A-arm arc and the steering linkage arc, so the bumpsteer should not be any worse than factory. Although "normal range" for you is now more into the "stock compression" range of travel, so maybe. Also, the lowering springs should be stiffer to keep from bottoming out, and should reduce the normal suspension travel, which another factor towards "no worse than stock".
Since you are changing springs, this is a good opportunity to measure your own setup: With suspension reassembled sans spring, move the knuckle from full droop to hitting the bump stock, record the height versus the angle at the wheel mounting surface, and you will have your bump steer curve.
If you had a bumpsteer kit, you would then make adjustment and remeasure to find the best curve.
Good for theory, but sorry I don't have a definitive answer.
Transmission: MD8
Thanks for your input MoJoe. Reading your response, and some of the other threads that I just listed make me realize how much I don't know! Got lots o' learn'in to do!
Car: 87 IROC
Engine: L31 350
Additionally, you can measure the curves with the steering to left, center and right to get the complete picture.
Dean
ps- in other words for a quick example- both start at 4* caster, at 2" bump compresson travel the OEM strut angle coukld go aprox 6*. the lowered strut angle could go to 9* caster . The steeper angle tilts the outer tie rod back in relation to the inner tie rod in lateral form. This tilting will shorten the length in geometric form of an arching circle.
Linson
10-01-2015 09:50 PM
