is this a f-body piece?
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
hi
I've found this piece on the ground when my ball-joint failed and the wheel alomst went away.
Is it something from our car? Perhaps it was already on the ground.
thanks
thanks
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Re: is this a f-body piece?
That is a balancing weight they glue onto your rims to balance the tires. You should find which rim looks like it is missing this and have it balanced again
Received 1,672 Likes
That's a wheel balance weight. Not the glue-on type though, it's the "real" kind, that clips onto the edge of the rim.
Probably got knocked off of the wheel when the BJ failed; hit something most likely.
Get that wheel re-balanced.
Car: 1988 Camaro
As others have said. It's a wheel weight. Every car, every wheel will have one. Some may have 2 or 3 lol. May be on outside or inside of wheel. Can be diff sizes (longer or shorter)
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
That's the style wheel weight that they might try to use on a nice set of wheels putting them on the outside lip and damaging it. Not only that but they look terrible.
I specifically tell anyone mounting tires on my wheel not to use them. Only the stick on type that goes on the inside of the wheel.
B4C5.7
Exterior Parts for Sale
12-15-2015 07:09 AM
1Aauto
Sponsored Vendors
12-09-2015 03:08 PM
