Founders vs Umi Upper Panhard - Difference?
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Any difference between the two beside price? They both seem to be built the same. I cannot see any difference even in the description. Thank you.
Re: Founders vs Umi Upper Panhard - Difference?
I can't speak for Founders but all UMI Products are made of 100% "US" Steel here in Philipsburg,Pa. We design,test and race all of our products. We manufacture most everything we offer including powdercoat in house.Nothing outsourced to any other machine shop.
We offer a 2yr craftsmanship warranty. Basically you break it we replace it!
If you need any pricing or info just let me know.
Craig
Craig
All of the Founders Performance parts are also made with "Made in USA Steel" along with everything else being manufactured in San Luis Obispo CA. The only thing we outsource is the powder coat which is done locally so we can control the quality of it. We however have a lifetime warranty on all of our parts (except for rod ends and spherical bearings) and our parts are on average 30% less expensive compared to everyone else.
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I can't speak of the UMI, but I have a Founders PHB relo and it fits well. I did have to slightly bend some metal on the RH frame rail so it could fit flush. For what it is worth I also have the Founders strut mounts which are very nice pieces. Overall the quality and price point of the Founders products is unrivaled IMO.
I just wish they would offer us a reasonably priced STB!
Axle/Gears: 9-bolt/3.45
Competition is healthy, no doubt. Both companies are very 3rdgen-friendly with regards to products, quality and service, even representation. I've purchased from both, and I will continue to purchase from both. I wouldn't want to be forced to state that one is "better" than the other, as we can't go wrong with either company. I want them both to stick around for us, so I hope both are happy with a share.
I think it's safe to say you will get a quality product from a number of reputable companies that manufacture aftermarket components that will be an upgrade to the stock stamped steel factory suspension components.
Craig
Craig
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I had the UMI PH-Rod, Uppers, SFC and LCA's in my 87 TA (which I sold three years ago). Great pieces, and excellent build quality.
I currently have Founder's PH-Rod (adjustable), Upper and LCA's that will go into "The Project". Quality seems similar.
+ 1 for dust boots on the strut tower plates
I will say that the UMI LCA's seemed heavier..
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Or, a bellows to fit over/protect the strut rod in the wheel well, since the factory "cylinder" doesn't fit with the aftermarket strut mount?... this would be between the spherical bearing and the strut body.
Car: 1986 IROC Z28
I understand that thisnis a comparison between UMI and Founders but where does BMR fall into place? Im looking at all my options. Thanks!
Car: 1986 IROC Z28
1 Post
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
are you supposed to pull the factory covers off the struts? when using the upper strut mounts?
1 Post
Car: 1991 camaro RS
oh crap ya mine didn't come with instructions we installed the mounts with them and did the alignment guess ill have to pull them and realign
everything in my car is founders, except umi strut tower mounts, lets be serious, these are two great company's, but founders cant be beat when it comes to price! and there's no quality sacrificed, easy company to deal with also, thanks
