Bushings for hollow front sway bar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
I have this bar and the diameter ranges from 33mm - 36mm depending where you measure the things... It is 33mm where the bushings mount, and I'd like to get 33mm energy suspension (or prothane if they actually fit) bushings. I searched older threads and they talk about energy offering only 33 and 35mm bushings...
but all I can find now is 34mm and 36mm bushings from energy for these cars.
Does anybody have a part number for the 33mm energy suspension bushings? If not, I see moog makes some 33mm bushings that are blue... are these just as good or better than the energy ones?
Thanks in advance,
Cale
Thanks in advance,
Cale
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Re: Bushings for hollow front sway bar
I measured the bar again. It's not perfectly round. Got a reading of 34mm in a couple different spots where the bushings mount, so I ordered the 34mm bushings from energy.
dennisschreuer
01-20-2016 09:16 AM
