Koni Shock Installation help
Transmission: Pro-built 700R4
Does anybody have some good directions on installing Koni Yellow shocks? I have installed other shocks without any issues, but I got some new Koni Yellow shocks recently. I want to install them correctly, but the instructions that came with them really suck. Any help is appreciated.
Re: Koni Shock Installation help
I didn't even look at the directions. Just unbolted the old and bolted in the new. I changed the front springs while I was at it and put blue locktight on the 2 large spindle to strut bolts.
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Suspension is a fairly straight forward job. May need a front end alignment afterwards, just depends on how much you are replacing/replaced.
No, its just the rear shocks. I've done shocks before, just wanted to make sure I did these right. The pictures in the instructions make it look like using the improper setting with mess with ride height. Just wanted to make sure I don't have to do the job twice.
WTR388
Aftermarket Vendor Review
02-18-2016 07:04 PM
instaldave
02-11-2016 12:26 PM
