Lakewood traction action bars
Car: 91 Z28
Engine: 383-Carb
Transmission: TH400/3500 Stall
I have a 91 Z28 & am using a set of 21700 lakewood traction action bars.question is do I still have to use the torque arm? These lakewood bars are supposed to stop the rear end from moving the same as the torque arm! Correct? I'm using a Stainless Works long tube header kit & was using a BMR adj torque arm n BMR trans mount n torque arm relocation bracket. Can't use the BMR stuff cause exhaust won't clear .any help is much appreciated!
Re: Lakewood traction action bars
i'd say yes if your strickly drag racing. any street driving and your asking for trouble. JMO. how will the rear articulate over odd bumps and such with that design?
Car: 91 Z28
Engine: 383-Carb
Thanks!
Had a brain fart.thought them lakewood bar struts would stop rear end from moving. Found a torque arm mount from Hooker Headers(ment for 4th gens) ad to modify my stock trans crossmember w/ 1/4" flat stock. Should work ok! I hope.
87_gta
06-11-2017 11:50 PM
85@IRocZ
17
03-05-2016 12:00 PM
