Castle nut stuck on spindle
Hi guys so I'm new here and yesterday I ran into a bit of an issue, my front passengers side wheel bearing exploded without any warning signs. The thing is I just replaced them about a month ago and maybe put 200 miles on the car. So no big deal right just put some new ones on but the issue im having is that my castle nut seems to have welded itself to the spindle preventing me from doing anything. Just wondering if theres anyone out there who knows how to get it off or if I'm just going to have to buy a new spindle, thanks.
And by the way it's an 86 iroc z if that helps
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: Castle nut stuck on spindle
Have you tried heating the nut red hot?
Engine: 4++,350 & 305 CIs
I'd cut the nut off with a cutting wheel.
Get a can of MAP gas and try that. Get it nice and hot and then hit with an impact or a breaker bar or maybe a ratchet and hammer combo
1 Post
If its stuck on there is probably already some level of damage to the threads. If you heat the nut it will grow & do less damage to the threads coming off. Make it glow then hit it with an impact like Midias said.
Thanks everyone for the help I'm really impressed with the response time on this site!
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
if the exploding bearing did enough damage that you can't get the nut off, then the spindle is probably junk.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Wheel bearings exploding ?
Possibly to tight or not tight enough.
mikeyt
03-21-2016 08:21 PM
NHL69
Exterior Parts for Sale
17
03-17-2016 09:36 PM
