Rear end off center
Car: 91 ws6
Engine: Carb'd 334 stroker
Hello all, recently I picked up a 92 formula for a good price..seems in good shape, minus the nose. This thing was in a front end collision with a fence post, bent the front frame rail at the core support. Rest of the frame looks fine, all body panels line up nicely, doors close like a new car, hatch is lined up..
Pulling the has tank out a few days ago, I found what was catching the rear wheels (assumed e-brake locked, never actually looked) and saw the drivers side wheel was running on the bump stop.
It has the factory wheels and spacers, factory size 16" tires. The passenger side is a good 3-3.25" ish out from the bump stop, so the rear end isn't centered. Even with the panhard and everything removed, it still sits over some.
Upon looking at the frame, it appears this thing was also in a rear end collision at some point..frame rail on the pass side just behind the bottom of the gas tank is kinked a little.
Now I looked at the rest of the frame, and I can see no other evidence or damage on the rest of the frame in front of that point, and the 7 or so inches up in front of the core support.
Why else would the rear be that off centered?
Received 1,664 Likes
Re: Rear end off center
Install a known good Panhard bar. I suggest aftermarket, simpler is better, all you need is yerbasic tubing with 2 bushings at the ends. No rod ends, no adjustment, just buy one and stick it on.
Car: 91 ws6
Because the Panhard bar that used to be there was bent/broken/ineffective/dead bushings/etc.
And without ANY Panhard bar there, there's nothing at all to center it; it just goes wherever it feels like.
Car: 91 ws6
I've had 6 birds in the last few years, one stock height, one lifted 4", current one lowered 1", the rest I don't remember, none were like this.
If this was caused by the frame being bent in front of the axle/mounting points, wouldn't that be a pretty significant bent to cause the rear to **** over like that?
I ask because crawling around under it, I find zero evidence of a bend.
It appears straight, just pushed over to the pass side. The factory spacers are all there as well, same size wheels/tires on both sides.
BG1959
07-20-2016 02:22 PM
