Koni yellow fronts with KYB AGX rear?
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I need to replace the crappy struts I have upfront, but I have AGX shocks in the rear already. If I'm going with Koni's do I really need to get all 4, or are the AGX fairly comparable?
I have Eibach springs in the front, an progressive Moogs in the back. Car sits pretty level which is why I didn't put Eibachs in the rear.
The rest of the suspension is decked out. Spohn torque arm, LCAs, panhard. Big sway bars, wonderbar. Poly bushings in the front A arms. Kenny Brown SFCs.
I need to get a STB, and caster camber plates, but that's about all that's left.
Re: Koni yellow fronts with KYB AGX rear?
The only problem I see with that is that the Koni's are rebound adjustment only.
The KYB's adjuster adjusts both rebound and compression together.
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Why wouldnt you just put agx struts up front? Matched set is best in your case.
marco33
04-13-2016 11:53 PM
rickyzZ28
03-14-2016 07:52 PM
