violent shaking
Car: 1984 camaro
Engine: 305 v8
Transmission: auto 4 speed
violent shaking
ok so sometimes when im driving and i hit a bump in the right way my car violently shakes side to side until i stop the car, what causes this and how can i fix it
Car: 1984 camaro
Engine: 305 v8
Re: violent shaking
ok i knew they were gone but i wasnt sure if there was anything else wrong that i need repaired
Car: 1988 Pontiac GTA
Transmission: 700r?
Re: violent shaking
If all of the suspension components are original, then basically everything that has rubber bushings. Jack up your car so the wheels not touching the ground, have a buddy turn steering wheel left and right, and you under the car look at the tie rods, if you see the joints doesn't move smooth (looks like they want to pop out) its time to replace them. Also while the car jacked up, by hand, try to "wiggle" the wheels in X and Y axis. If wheels feel sloppy, its time to do some suspension maintenance. Check your shock booths for rips too, under the hood.
BlackThunder
Exterior Parts Wanted
05-23-2016 06:12 AM
