Stronger Suspension questions
Car: 1987 Camaro
Engine: 350 HO 360whp
Transmission: Borg-Warner T5
I got a 1987 camaro with a 350 swap and was needing some ideas for a stronger suspension as this car is really bouncy and it sometimes smashes the exhaust. Im always lost when it comes to finding the right part if you guys could help and maybe it'll help others as well that'd be much appreciated thanks.
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Re: Stronger Suspension questions
What do you mean by "bouncy"? And under what circumstances do you hit the exhaust? And what suspension is under the car now? (V6, V8, aftermarket, etc...)
Examples please. The better you explain the better advise you'll get. Could be as simple as worn out shocks.
Car: 1987 Camaro
It has the original v6 shocks. And what i mean by bouncy is that theres looots of play in it and anytime your speeding and go into a fairly large dip in the road it bounces and hits the exhaust. Theres way to much play in the shocks.
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
Obviously you need shocks. Check pivot points on suspension arms. Go with springs if you want to stiffen the ride some.
You can go with a lowering kit, if you want, or a set of stock MOOG springs for an L98 equipped car.
Moog 5660, 5662, and 5664 have varying spring rates from 650-750lbs and were used on various V8 thirdgens.
Most L98 cars got 5662's which are 748lb/in
http://www.moog-suspension-parts.com...il_springs.asp
Car: '79 Pontiac Trans Am
Engine: 400
Transmission: Super T10 4spd
Axle/Gears: 8.5 10 bolt with 2.73 gears
I'm with the other in regards to shocks sounding like the culprit. I would try an adjustable shock unless you're dead set on non-adjustable bolt-on equipment. An adjustable unit would allow you to tune ride quality to your liking.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i ran the stock V6 springs and what i think were the stock struts and shocks for 3 years after swapping a V8 into it, and it wasn't "bouncy".. it did turf out the exhaust a couple of times, but that happens with long tube headers and pipes that hang below the trans crossmember..
now that i've got som Moog IROC replacement springs in the front and rear- still the stock struts in the front, but some DeCarbon 4th gen shocks in the rear- it doesn't bounce at all...
so, yeah, to tie this all up: you need new shocks and struts..
Car: 1987 Camaro
dennisbernal91z
04-14-2016 05:42 AM
theformula
Aftermarket Product Review
10-14-2000 05:17 PM
