Indexing springs
Car: 1992 Z28
Engine: 5.7
Indexing springs
I had my front springs installed by a shop that claimed to know what they were doing. Long story short I believe they didn't index the front springs correctly and now my rear driver's side is 1" taller than my passengers side. Does anyone know how I could index the springs while still installed on the car? Any info is greatly appreciated.
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Re: Indexing springs
Put a floor jack under the A-arm, undo the top shock mount and lower the jack until you can twist the spring. Jack the A-arm back up and tighten the shock top nut again.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
You said the rear of the car is higher? Not the front?
If you feel they were installed wrong take the car back and have them fix it.
Engine: 4++,350 & 305 CIs
If you looked at these cars when they were new, that's how they sat. For some odd reason the right rear is taller, some more than others.
I have shimmed the left front spring to make the right rear come down or equal out.
