k member triangle braces and swaybar mount under gearbox torque specs
Car: 89 Formula
Im getting my 86 trans am back together and I cant find the torque specs for the triangle braces on the k member and the sway bar mounting bracket that is under the steering box. Both of my manuals don't show anything about them.
Received 1,666 Likes
Re: k member triangle braces and swaybar mount under gearbox torque specs
Torque goes with hardware size. You don't need "specs".
That would be, somewhere in the 40 - 45 ft-lb range for the sway bar bushing bolts (10mm), and 20 - 25 for the little braces (8mm).
Just also be cautious that the hardware is meant for automotive use. run of the mill grade 3 stuff bought from a hardware shelf will twist or bend. When I first started I learned this lesson. Any suspension or engine hardware should be the best you can buy. Heck I even switched to stainless for the sheet metal screws.
IROCZ1989
Aftermarket Product Review
09-19-2016 12:04 AM
