Wheel bearings
Car: 1982 Pontiac Trans Am
Engine: 5.0 V8
Transmission: Automatic
Wheel bearings
I have a 1982 TA and the wheel bearings listed are to small for the knuckle. Do not have the original wheel bearings or rotors. The driver side knuckle says GM4 and 1197N; the passenger side says GM6 and 1198N. Measured the upper shaft with a crescent wrench and t was 1 1/4 inch.
What type of spindle/knuckles do I have and what are the inner and outer bearings to use?
Received 1,666 Likes
Re: Wheel bearings
You have 3rd gen Camaro/Firebird spindles.
Correct bearing part #s are Set 6 & Set 34. A6 & A34 in some brands.
You'll need the grease seal too; part # is 8871.
