Rag Joint Eliminator Steering Shaft
Before I go out and buy this, has anyone purchased and installed this specific item? And if so, how do you like it?
http://www.rickscamaros.com/camaro-s...FQqAvQod6VUMrA
Car: 91 Firebird
Engine: 6.0
Re: Rag Joint Eliminator Steering Shaft
The link you provided doesn't bring you to a specific part, just Ricks Camaro page.
If it is the solid disc to replace the rag joint, I remember people saying that it would bind up the steering.
I personally use the astro shaft from Walter racecraft
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If it is a flexible part it should work but a solid replacement part
will bind up and break parts I know from experience.
Tidan (05-15-2020)
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Everyone, myself included, seems to use the astro van shafts. Paid 75 or so and it installed in no time. Unless the thing has magic pixies in it, not sure why I'd consider a $300+ replacement.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Here's the proper link.
http://www.rickscamaros.com/camaro-s...1982-1992.html
NOTE: Their website or TGO breaks the link when forwarded.
It looks like a great new piece of equipment. Me being me, I'd like to know more about it as well. I'm more for new than replacement swaps and such but I myself bought the Astro Van shaft from a guy on here. Can't recall his name but he should still be selling them. Good luck, hopefully someone can chime in.
People have used the equivalent from flaming river or borgesen.They seem to work fine, personally i think its overkill.I dont see a damper (unless thats it to the right).You want one to isolate vibrations.
I also did the astro van mod, $8 & 12 trouble free yrs so far.
Well I have been researching the Astro/Safari van mod. Seen almost all the videos. And yes, it seems the best way to go. Just the minor work to get it to work for the F body is what I don't have that much free time to modify it. In one video, it shows the guy having to make a notch at the column coming from the firewall into the engine bay to make the joint bolt fit since the pre-existing bolt hole is no longer used.
Ok, well that solves that issue. I still have to clock the joint though right? grinding down the shaft so that I can clock it it 90 degrees and then re-weld?
EDIT: Disregard. LOL
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
so a quick double check and this is just the Detroit Speed kit that Rick's camaro jacked up the price on
http://www.detroitspeed.com/1982-199...shaft-kit.html
