Lakewood LCA's
Old 02-19-2002, 05:05 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 305 Tpi
Transmission: T5 Manual
Lakewood LCA's
These seem to be far cheaper than any of the others. Is there a catch? Are they much better than stock?
Many thanks
Old 02-19-2002, 08:51 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Lakewood LCA's
Many thanks
yes. lots better. comes with polyurethane bushings and are greasable. now ones like bmr are larger diameter bars that are the same diameter as the bushings. the lakewood bars are 1" square tubing. have them on my car. no more oversteer and i get 2.005 60ft times. also have their adjustable panhard rod.
Old 02-19-2002, 11:31 PM
turningfast's Avatar
I have the lakewood pan and control arms too. I was also skeptical of their price, but ar egood stuff. as mentioned above, they are greasable, which is very important when it comes to poly bushings. The parts firmed up the rear suspension soooooo much. Before, with a person pushing back and forth on each side of the car, you could see the rim and axle moving back and forth at least an inch. Now it does not move at all.
Old 02-20-2002, 04:01 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 305 Tpi
Excellent stuff, so a big improvement over stock but there are others out there that do the job better
Old 02-20-2002, 05:41 PM
mrr23's Avatar
Engine: 360 HSR
yes.
1992rs/ss
05-19-2020 07:02 PM
Hotrodboba400
12-10-2019 07:07 PM
1992rs/ss
16
01-28-2016 09:58 PM
Jorlain
10-08-2015 01:57 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Lakewood LCA's
