smog pump
Old 02-08-2003, 02:42 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
smog pump
i was readin the tech article on removing the smog pump on serpentene f bodys and i was wondering exactly what does the smog pump do is it the source of the egr and will removing it mess with anything such as the egr that might harm my engine i dont have to pass emissions in my state i already have my cat removed but i had the air tube welded into the pipe that i put in place of my cat any info will help thanks
Old 02-08-2003, 07:55 PM
iroc22's Avatar
Removing your AIR pump will do essentially nothing except remove 1 or 2 pounds off of your nose. EGR is an entirely different system altogether.
Old 02-08-2003, 10:52 PM
deadtrend1's Avatar
ill just cut and paste this from the thread 4 posts up that i wrote.
the AIR pump becomes a Idler pulley 30 seconds after a cold start. It pumps air into the cat so it warms up quicker to make the EPA sissies happy. After the cat is warmed up, selenoid switches and the pump becomes usless for the rest of the day ..... WAY TO GO GM!
also, if you take the EGR off without disabling it in the computer. Then the computer will hate you and the car will run like crap. Leave it in for awhile.
italiano67
12-11-2016 09:21 AM
J.C. Denton
08-31-2015 03:11 AM
Victor6
08-30-2015 02:09 AM
camaro_rs350
Northern California
08-18-2015 12:38 AM
mustangman65_79
08-07-2015 09:55 PM
Quick Reply: smog pump
