TBI-Won't start
TBI-Won't start
Just swapped a TBI-305 from a 91 Camaro RS into my 73 FJ40 Landcruiser. will run all day if i trickle gas from a can into the TBI but it will not start by itself...my buddy thinks it has something to do with the VATS module...if so, how do I get around this...don't have the original key to measure the resistance, a wiring schematic would sure help...what do you guys suggest? Thanks.
Re: TBI-Won't start
what kind of ecm do you have ??? i have a 1974 fj40 tbi and i use the 16197427 ecm 1995 TBI and it runs a fastburn 385 engine about 400 hp if you have this problem there are some things that you need to know on the fj40 land cruiser, first would be the fuel tank, it has a vented style but if you install the fuel line's to the TBI wrong the fuel pump will not be able to get fuel from the tank and this will cause a vacume pressure build up in the tank that will over come the fuelf pump and can burn up your fuel pump
if you want you can e-mail me directly and ill help you with some technical information that i have on the fj40 1973 years because your fj40 and mine are the same, and i have figured out this problem allready i had the same problem, and it requires some knowing of where to put the return line and also the feed line
e-mail me at ertiself@yahoo.com ill help you...
Re: TBI-Won't start
i need some one to help me on this please.. i have a fastburn 385 engine with the 208 / 221 cam in it the lobe sep is 112 and it produces very good vacume i have a 16197427 ecm with a holley 670 TBI unit.. the injecters are 60pph at 12 psi and 85pph at 21 psi adjustable fuel pressure regulater.
the heads on this engine aree 210cc raised intake runners type. and are votec style. i have been told many stories that this will not work and that ill have to go to multiport and then i have been told that it will work..??? what i need is some one that knows that this will work or not? and can point me in the right direction to some one that can program this system abd ecm to work properly. my idle is very rich and my LT fuel trim and ST fuel trim are HIGH around 156 or higer on the LT and st is 130 or so some times higher.. howell injection can not fix this.. and turbo city does not program TBI any more.. can som one help please.
my email is ertiself@yahoo.com please e-mail me any time..
in need help on this....
92camaroJoe
08-13-2015 06:07 AM
