TBI 305 to 350 questions
Old 04-17-2004, 12:38 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I want to get the best power out of my newly acquired TBI motor, it's from a 89 camaro and has the 700R4.
under all the 305 stuff is a 90 L-98, it seemed to run okay in the camaro, never seemed to starve for fuel or idle weird, should I leave it as is, or should I get a 350 chip and injectors.
I plan on swapping out the 305 heads for 305 h.o heads will pushrod legth be a problem or is it bolt on and go, I realize about the manifold bolts angle, as well as the accesory bolt missing. or should I get a set of f-body 350 heads.
it seems to be geared pretty high but has no problem breaking its tires loose at will, should I leave the gears alone since it does accelerate very nicely.
I want to get at least the power it made when it was a L-98, I have a edelbrock performer 4 barrel manifold, with a adapter will egr clearance be a problem and will hood clearnce be a problem as well.
thanks
Old 04-17-2004, 09:37 AM
Supporter/Moderator
ShiftyCapone's Avatar
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would use a set of L98 heads. That way your compression will not be out of this world. You deffineately need to get into chip burning and use larger injectors. You may want to put another cam in there if you are pulling the heads.
Old 04-17-2004, 11:10 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Yeah I'd agree with Shifty: go with some L98 heads not 305 heads. Use that manifold you have and absolutely get some headers, those manifolds are choking the life out of that engine.
Old 04-17-2004, 01:50 PM
Jproz1167's Avatar
whats a better cam than the 90 vette cam, thats what the short block was from, I also need it to remain emmisions legal
Old 04-17-2004, 03:19 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
There it is again.
Old 04-18-2004, 12:47 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by Gunny Highway
There it is again.
It is the golden rule You are all over me for that
Old 04-18-2004, 12:36 PM
Car: 91 RS
Engine: 350 TBI
Boredom is a horrible thing.
MustangBeater20
10-29-2022 09:20 PM
xkingcodex
02-12-2020 07:43 PM
Jake_92RS
01-28-2020 10:37 PM
dutch930
09-11-2015 06:58 AM
redmaroz
08-16-2015 11:40 PM
Quick Reply: TBI 305 to 350 questions
