casting# 193 heads
Old 07-31-2004, 03:04 PM
94zcar's Avatar
Car: 94 Z28, 92 s10 Jimmy 350 CID TBI soon to be Vortec TBI, 76 Pontiac Ventura LO3/4L60
Engine: Mega HP!
Transmission: 4L60
casting# 193 heads
Anybody know if casting#14102193 heads will work on a 92 TBI 305 engine? What are they off of originally? Looking for a better flowing head for my LO3 -Rod-
Mikejackson 75 (10-13-2020)
Old 07-31-2004, 04:09 PM
Supporter/Moderator
ShiftyCapone's Avatar
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What did they come off of. Check out www.mortec.com to see where they came from.
Old 08-01-2004, 08:44 PM
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
350 TBI heads..
-- Joe
Old 08-02-2004, 12:41 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
193 castings are the 350 TBI heads, IIRC.
Old 08-03-2004, 10:08 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Those are 5.7 TBI swirl port heads. They may flow a little better than your 305 heads but the cumbustion chamber is 64 cc and IIRC the valves will be shrouded by the smaller cylinders.
Old 08-04-2004, 12:00 AM
94zcar's Avatar
Engine: Mega HP!
Transmission: 4L60
casting# 193 heads
That is what I was afraid of, (TBI heads). I was hoping they were TPI or some other better flowing head.
I just talked to the owner of the local speed shop today about using a 350 head on a 305. He said he had built a few 305"s with better flowing 350 heads, but he found that the max cam lift would be around .480 Because of the small bore on the 305. Even less if you tried to mill the heads to make up for the larger chambers.
I guess it is best to try to find a better flowing 305 head. -Rod-
Old 08-04-2004, 12:04 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: casting# 193 heads
Every stock GM casting head for the most part is limited to this lift. It is not because of the bore size though. You would need to have the valve seats machined to accpet larger lift cams.
Old 08-04-2004, 12:28 AM
94zcar's Avatar
Engine: Mega HP!
Transmission: 4L60
RE:casting# 193 heads
Ahh, I though he was talking about the valves hitting the bore. Because the 350 heads have bigger (1.94 valves). .480 lift should not be a problem for me anyway because I have a 96 LT1 cam in my LO3. Around .470 lift I think.
But if I were to put 350 heads on I would want to mill them down to at least 58 CC to keep my compression up.
Them would the valves hit the Bore? Anybody out there done this? -Rod-
Old 08-04-2004, 01:27 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Re: Re: casting# 193 heads
Valve seats? The lift on the cam for most SBC heads are hindered by the clearance between the bottom of the retainer and the top of the guide boss.
Old 08-04-2004, 04:31 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Okay, I think the limiting factor is the springs themselves. In most cases the spring pocket would need to be machined to accept a larger spring for higher lift. The other problem is that with lift too high, the pressed in studs will have to be pulled and then the head tapped for screw in studs.
Milling an already thin 64cc casting down to 58cc's can most likely be acomplished by angle milling the heads. Then you will also have to mill the intake, so it will all fit correctly.
Here's some 305 casting numbers to look for, instead.
14102187 305HO, 87-91, 1.85-1.5, 58cc, 7 bolt ex.
14101081 305, 87-88 Camaro, center bolt VC (TPI)
14014416 305 HO, 80-85, 58cc, 1.84-1.5, 165/59cc ports, 7 bolt ex.
14022601 267, 305 HO, 80-85, 58cc, 1.84-1.5, 7 bolt ex.
Don't waste your time with the 193's. They are the same as the 305 TBI heads, just bigger valves and more cc's. You really dont want to put all that money/time into a set of heads that still wont flow, do you?
Old 08-04-2004, 11:15 PM
94zcar's Avatar
Engine: Mega HP!
Transmission: 4L60
re:casting# 193 heads
Thanks for the info and the casting #'s. I'm gonna lok for one of those 305 heads. sounds like it will be less $$ and work. -Rod-
Old 08-05-2004, 01:28 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Those are the 305 TBI heads, best avoid these as well.
Old 08-05-2004, 12:26 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Oh sorry Stek, I thought the 305 TBI heads were 14102191
My bad.
Old 08-08-2004, 08:39 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
I am wondering if you guys can help me out.Here is the question.
I have in my possession a 350 out from a pickup and i want to rebuilt this motor to put it in my car.The head casting #is 14102191 and the block # is 14093638 so this is a LO3 or what? It will be better if i keep it TBI or should i put a Carb. in there?And last what cam you guys sugest?
I apreciate the help since i am new to this.
Old 08-08-2004, 10:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
L03 is the 305 TBI. L05 is the 350 TBI. By the head castings, you have neither, although the block may be the same as an L05.
191 heads are truck heads. Nothing performance about them. probably fall along the lines of smogger stuff.
Sounds like you have a typical flat tappet cam truck engine.
What is the budget? What do you want out of the car?
Old 08-09-2004, 09:47 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
block casting # 14093638...350...87-95...2 or 4...Roller or flat tappet cam one-piece rear seal
head casting# 14102191 305, 350, 87 up center bolt VC
compliments of mortech.com
Old 08-09-2004, 07:32 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
The motor is all apart. It had two pistons with a hole on top,Was taked off a pickup truck, it was running good before the two pistons f***d.My question is can i put this motor on my car, i am thinking to put i carb there.But looks like i am gonna have to change the heads.My budget is a little bit tied,but i'll try to manage it.
Old 08-09-2004, 09:33 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yes you can use it provided you do all that is necessary for the 305 to 350 TBI swap.
Old 08-25-2007, 02:17 PM
bad300sport's Avatar
Car: '69 Dodge Coronet, 88' Camaro SC
Engine: 440, 350 respectively
Transmission: 727, 700R4 respectively
Axle/Gears: 3.90s for the 'Net, 2.73 4 the Maro
Just curious, sas the L05 a TBI engine only?
Anyway, I run an Edelbrock 650cfm carb and Edelbrock aluminum intake on my '85 Z-28 and it runs great. The 350 came with TPI but since my 'Maro didn't have the harness to support the TPI, I slapped on a carb and electric fuel pump. I'm plannin on cam and heads next then headers and new exhaust.
Old 09-13-2011, 08:56 PM
Lusk91's Avatar
Car: 91 Firebird Formula
Engine: 305 tbi
Transmission: 700 r4
Will it hurt to put on the 193's on a 305 tbi. I did how much compression am i gonna loss? i havent started it yet!
Old 09-16-2011, 09:34 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Holy old thread Batman!!!
You will go from ~9.0 to ~8.3 cr. The performance that you think you will gain will be lost in the lack of comression ratio.
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
FormulasOnly
09-06-2015 10:42 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: casting# 193 heads
