LT1 cam digest (the ultimate one)
#51
Re: LT1 cam digest (the ultimate one)
Ok ive got a few questions ive got a jasper crate engine and it came with the roller set up can i just use the roller lifters and pushrods with the lt1 cam or do i have to get the ones for the lt1 also ive got the jet stage 2 chip is that good enough of a tune to handle that cam or will i have to get a custom one thanks in advance
#52
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can re-use the stock LO3 lifters and pushrods (assuming they are in good shape). The Jet chip is a waste of time and money. To properly tune your new cam it will require you to burn chips yourself. Fear not, there is plenty of info on this site to help get you started. No off the shelf chip will suffice.
#53
Well that sucks tuning looks kinda complicated can anyone simplify it for me lol and were can i buy a cheaper cable ive got the money just dont want to spend 60$ on a cable
#54
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
degreeing the cam?
Back once again..
Shifty, this is a GREAT article. This will be my first cam swap too and I was a bit nervous until I saw how simple you made it seem.
You didn't mention anything about degreeing the cam. I run TPI and a non-LT1 cam but I'm betting whether to degree or not is the same answer. So, is it necessary? If so, do you have another article on how to do that?
Thank you...
Eric
Thank you...
Eric
#55
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
one more question, are you guys using any kind of cam button on this installation?
#56
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
If you have a 87+ roller motor, they incorporate a retaining plate that eliminates the need for a cam button.
#57
Engine: LS1 / L03
thanks for clearing that up, i wasn't aware of the fact that the retainer plate eliminates the need for a cam button. great article btw *****
#58
A quick question I think I know the answer to:
I am building a 350 LO5 TBI for my 89 Formula. In your opinion, would it behoove me to install the LT1 cam now, and try to tune for it later, or get the 350 in the car stock and running, then add the LT1 cam later on with the motor in the car.
Obviously, it's easier to install a cam while a motor is basically ripped apart (at this point it's only the balancer and behind to remove). But would it just create a headache when trying to get the car started and running well after the 305-350 tbi swap? (all this based on the assumptions that 1- I've read the 305-350 swap sticky in the tbi forum and 2- I have no tuning experience)
Your thoughts are valued.
#59
Engine: LS1 / L03
i would say it all depends on whether you have time to fart around with tuning it or not. if you need to swap it and then drive to work after the weekend the lt1 cam should go in later of course
i would really put it in with the engine apart.. about the tuning part, you might want to consider these two opportunities: if you say i'll throw in that lt1 cam (which is pretty mild for a 350 anyway), tune it and leave it like that for some years, you would probably want to burn a chip and leave it.
you wouldn't want something like the EBL (dynamicefi.com) then, because you will never need to re-programm anything -- on the other hand, even if you choose the fully assembled EBL Flash version, it's like 400 bucks, reprogrammable and has a lot more nice sh*t put into it than prolly any of the stock tbi ecms, and if you have to buy all the prom burning stuff you won't get away much cheaper anyways (but you could still borrow it or have someone tune it?)
just some thoughts hth, ownor
#60
thanks, ebl seems like an option to consider. Really though, I plan on doing the motor in affordable steps, tuning and learning as I go. Start with just the stock 350 and cam, then go from there.
Thanks for the advice, I don't want to hijack the thread though. Just figured my question would be relevent for many considering the LT1 cam as an option while building a motor.
#61
1 Post
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
New post to old thread..... I have done the 305 to 350 swap. I am pulling the motor this week to 'freshen up'. I have a 350 tbi (9C1) my engine guy tells me that I can increase the cam size slightly and the computer will make up the difference. I already have the bigger fuel pump and the 65 lb./hr injectors. Is this true or MUST I burn a new chip?
#63
From what I gather, you COULD run the LT1 cam without tuning, but the gains from the cam would be minimal if any. It could even take you down a notch.
It seems to me that more power could be made by tuning alone than doing the LT1 cam swap without tuning at all. Obviously if you're going to tune and you're already "freshening" might as well toss the bad boy in there (can't argue w/ it's price!) since it's tried and true and with some advice from the tuning gurus here you could get it running very strong.
These are basic assumptions I've made based on using an LO5 truck 350... not a 9C1. Assuming you are using the 9C1 ECM, things might also be different. Chances are though, you would really want to get into tuning it. I'm not at those stages yet myself, but it seems to me that if you have a computer, an ALDL cable and a dream you can pull it off (with some serious effort).
#64
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
I have a stock L03 engine and want to add better heads and a streetable cam. I must have read it many times on third gen site but I get lost sometimes and cant refind the info. I would like to know which heads I can buy used and which cam is recommended. Please steer me to the sticky on my car and heads. Thanks
Robert
Robert
#66
I see you noted that you hate the locker rear. I was planning on changing my gear set in my car soon and was wondering what you would suggest. Thanx
Rockmann007@yahoo.com
#68
Car: 92 Camaro RS
Engine: 5.0 TBI
Transmission: 5 speed Manual
Axle/Gears: Stock 3.08
So I realize this is an EXTREMELY old thread, but I too have a question. I have lots of plans for my LO3 this winter while the car is in hibernation. I'm definitely looking into the LT1 cam and I have other ideas (such as Ebelbrock Performer TBI intake, Hooker Headers, Proform full roller rockers, and some machining to the heads.) I am already running a Hypertech Stage 2 chip on stock motor and the gain was actually unreal in my application. Much more throttle response, and better fuel economy while running 93 octane pump gas. Also was able to achieve 140 MPH with stock 3.08 rear and T-5 trans. (speedlimiter bypass switch on the dash, of course)
To my actual question regarding chip burning, would the chip I currently have handle the cam? General consensus is absolutely not, but I have no idea who near me knows how to burn a chip. Any help would be great!
And awesome article btw. I've been doing mechanical work for a few years now, but this is my first attempt at internal engine work, and I'm doing it in my personal ride!
#69
Car: 89 Firebird Formula
Im running the hypertec stage 2 in my firebird and the car runs good with it but to benefit from everything the tuning is the way to go. I had a guy near me do a chip for me and it runs a little better but i need better gears and more tuning.
Their is a section on here for chip burning a lot of great info.
#70
Car: 92 Camaro RS
Engine: 5.0 TBI
#71
yes i am running the lt1 cam and a lot of extras. and before the chip burning the car ran good with just the hypertech chip.
The swap is very very simple just remember to grind down the dowel pin.
#72
Car: 92 Camaro RS
Engine: 5.0 TBI
Thank you again!
#73
this is a great thread , i to am going to put a lt1 in my 305 this spring i would like to know if this will be a good cam for a turbo also i plan on adding that later in the summer . plus is there any vids of a lt1 cam in a 305 sbc ?
#74
Car: 92 Camaro RS
Engine: 5.0 TBI
I don't know what to tell you on the turbo issue, but it should work if your willing to put the time and money into doing it right. And as far as the vids, there are a few on youtube if you search it, but nothing great that I found. Maybe some members will post some videos on here for us to see if they have done this?
#75
89formula 50 do you have any track times or dyno numbers for your car ?
your motors kinda what i got in mind except i'm gonna top mine off with a t70 turbo .
#77
Engine: LS1 / L03
do you guys consider a t70 a bolt-on or what?
89formula50 gotta love that baby blue (maui blue?) of your formula sounds good except for a bit high idle.. did you do any tuning? also what rpm does it idle at with the lt1 cam, did you adjust it manually?
#78
i don't consider any turbo a bolt on unlless the car came from the factory with a turbo ( like my 05 srt4 did ) i have experience with turbo cars so i'm not blind to what it takes to do it . so no i don't consider this a bolt on .lol
#79
freaky - I have no dyno numbers. The car went 10.8 in the 1/8th mile. But come to find out my front calipers where locked up and causing a drag. SSo after replacing the lines and new calipers i havent taken her down the track again. Bit will have 3.73's this year so will get some new numbers.
ownor - Yeah the color is what made me fall in love with her. Plus the no rust factor. lol. The high idle was because i just had it all put together and pulled it out of the garage so i didnt get fumed out. The second vid is the first initial start. No tuning yet. this year thats getting done. And yes i adjusted the idle manually. And it idles perfectly smooth at around 800 rpm's.
#83
Car: 1989 Pontiac Firebird FORMULA
Engine: Rebuilt Chevy 350 in 2007
Transmission: 5 Speed Borg
lo3 is the replacment for displacment
#84
mines running 13.9 with lt1 cam
#86
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Technically it doesn't matter. However most people rotate their engine another 180 deg after they align the cam dot to dot. Thats puts #1 TDC at firing which helps initial stat up.
#87
Car: 91 RS
Engine: 305 TBI
Transmission: 700R4 shift kit vette servo
Axle/Gears: 3.73 Eaton Posi
So after I install the new cam would it be a good idea to have the heads ported and polished? Or just leave them alone?
#88
Car: 1989 Fourmla
Engine: 5.0 305
ik this is a old thread but I did the lt1 cam swap with my lo3 I have it advanced 4 degrees at the crank new double roller timing kit z28 springs 1.6 roller rockers new valves tbi 1" spacer ported tbi shorty headers I ran out of time on my bulid and I don't have the time or money to tune my ecm but should the car start im just wondering I got 2 weeks to get it done before I go to college it tried to start yesterday when I was messing with it but I kept catching my tbi on fire so I came to the conclusion my timing is off but when I get it to start will it run decent I did a full rebuild with out machining the crank and boreing but let me know some responses plz
#89
Car: 1989 Fourmla
Engine: 5.0 305
I did the dot to dot on the crank I read today I had it 180* off so I set it back im still no having progress if you have any suggestions plz chime in its all new but intake and block and crank I would enjoy some of you experienced guys feed back tomorrow im gonna pull number one plug again and try again from scratch
#90
Car: 90 gmc 2wd
Axle/Gears: 3.45
i didnt see or read anything about new push rods...with the stronger valve springs should i run stronger push rods or not didnt see that any where, im doing the lt1 cam swap on my 305 sometime this summer
#91
1 Post
Car: '91 Firebird
Engine: 305 TBI w/LT1 cam
Transmission: T5 swapped in
Axle/Gears: 9 bolt 3.27 w/discs
I used my original pushrods, lifters, and rockers with no problem. Just make sure they all got back in the same place they came from.
#92
Car: 1988 Firebird Formula
Engine: 305 Tbi
Transmission: Stock
Axle/Gears: Stock
Shifty I'm planning on purchasing the crate 305 tbi roller from oreillys and was wondering does this lt1 setup I found online would be good or is all the extras unnecessary I know you mentioned gettin timing chain, gaskets, and springs but this motor will be remanufactured through oreillys what do you think? Here's the link
https://www.google.com/shopping/prod...LXO4-7ogSRy7dw
#93
Car: 90 RS Wht/Blk Convert. Orig. owner
Engine: L03 & L31
If you're buying a new engine and planning on an LT1 cam, then you will HAVE to tune it.
At that point, why not just buy an L31 and tune that instead? It already has all the good stuff in it (B/D body LT1 cam, Vortec heads, 4.00" bore, 45 more cubes) and is ready for upgrades more so than a small bore LO3 is. Price is probably really close too.
#94
Engine: 305 Tbi
Transmission: Stock
Axle/Gears: Stock
Well the car originally came with a 305 and I'm trying to keep it original while adding power I'm not looking to do track time I just want the car to have a little more kick than stock cause those 305 stock sure are sluggish especially with the stock rear end
#95
If you drop the L31 in there, you get the LT1 cam, and you also get the much better Vortec heads which will provide you with a big boost in performance. From there you should only need the Vortec intake and most everything else should bolt-up. The car will run better, make more power, and get better fuel economy. All major pluses.
#96
I have an LT1 cam in my L05 swap. It keeps eating distributor gears. Is this a common problem? Has anyone else ran into this issue?
I originally had a flat tappet camshaft. I then swapped to an LT4 Hot Cam, and used the same distributor I had with the flat tappet. I had no problems with this setup. I then switched to an LT1 camshaft, thinking the LT4 Hot Cam was too big for my application. I again used the same distributor. It ate that cam gear in a few thousands miles. I assumed it was because it was for a flat tappet camshaft (even though it worked fine with the LT4 roller cam). So I replaced it with a distributor out of a 1992 Camaro with an LO3. It ate that distributor gear in short order as well. I replaced that distributor with an MSD (PN 8366) It has been in there for maybe a couple thousand miles. I pulled it out the other day to check it, and it is starting to eat that gear as well.
Martin
Martin
#98
1 Post
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
I've had a '94 LT1 Z28, a '91 RS LO3, and an '84 L69. The LT1 pulled 6200 just fine, on a Hypertech tune, and the specs on its cam are, except for lift, the same as the old L69 cam. My L69 would also pull 6000 RPM.
I once made my LO3 turn 6200, in first gear, but it is all done before 5500. Then I replaced the timing set and lost 500 RPM, suggesting the stock chain had stretched at least 5*
Replacing the timing set gained me no lower-RPM torque, either. I nearly went for another chain that could be delayed 4*.
The LO3 heads being swirl-port, they are all done at a much lower RPM than the LT1 cam, so this is not a good match. Better to try the RamJet 350 cam, #14097395, IIRC.
And aside from the heads, even if you do headers, cat-back, and a dual-snorkel, the cost of an Edelbrock Performer TBI intake manifold, the only legal upgrade, is as high as a GMPP Vortec TBI intake manifold, so why dink around with the LO3 at that point?
I'm currently buying a '91 Firebird LO3 / T5, and I had no thoughts of the LT1 cam in the LO3, so I started reading this thread. It makes no sense. Just because you can get the cam cheap and it pulls enough vacuum for the TBI is no reason to run such a mismatch.
If I do try the RJ cam, and I'm more likely to try milled L31 heads first, with the ZZ4 cam, but either way, I expect better results than this clustercluck.
