How high can I safely rev my motor? What potential do I have?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I have a stock L05 with about 60k miles. I've yet to go full out WOT for more than a second or two and I want to make sure my transmission doesnt do anything funky in upper RPM ranges and allow my motor to over-rev. How should I set my rev limiter?
I've always wondered and I think its time I just threw out this question. What can I get out of my EBL controlled TBI 350 with full bolt ons and still have it be a reliable daily driver? What about heads/cam/intake? Any chance of going mid 13s? I am definitely sticking with TBI. Lets assume I have a 3.42 posi, even though I have 2.73 open right now.
Car: 1983 G20 Chevy
Transmission: 4L60
Injector Duty Cycle, Fuel Flow, and Valve springs are going to dictate redline. I have seen mild bolt-on L05s run out of fuel at 4,500 with the stock injectors/fuel pressure. On the otherhand, I was spinning my cammed but otherwise stock L05 longblock to 6,000 RPM on s regular basis. 5,000 rpm is well within limits and my non-valet rev-limit is now set at 5,500. My WOT 1-2 shift occurs around 5,350 or so.
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Good question.
I run my tbi up t0 5500 no problems, and on a few occasions went to 6k when it was cold out.
I am running stock heads/cam/fuel pump. I recently threw in an AL flywheel. That along with a carbon fiber shaft that I picked up used reduced my rotating mass significantly to spool the motor up faster and higher. Now I really need to dump the 3.42s to some 3.90s or 4.10s to get full benifit of the t56.
I do question the stock tach. Had a friend that had an autometer and the stock tach together and they were off alot.
