help fuel pump
help fuel pump
second week in a row i manage to break something else but i need your advice or someones knowledge to make sure i fix the right stuff..
while changing my spark plugs i found a stray wire on the passenger side.. asked my step dad about it he put it on the starter didnt help my car.. my car wouldnt turn over anymore it cranks but doesnt turn over..
when i ground this wire out you can hear a clicking from the fuel pump relay. did we fry the fuel pump relay? you cant hear my fuel pump turn on at all anymore. i cant find a fuse anywhere my ecm fuse is good so i am wondering is it the fuel pump relay?
thanks
Shawn
91 RS 5.0 TBI
14x3 open element.. i liked alot
160*stat... made my car run a lil cooler
msd coil and taylor wires ...not noticed
with split fire plugs... which suck switching to rapid fires soon..
removed rear hood seal.. runs much cooler i liked
accel cap and rotor... coming soon
coming soon 3.42's with slp posi.. my first big mod!!!
Clarion cd player 2 planet audio 6x9's 2 lanzar tweeters and one MTX 10" sub in a bandpass all running off 2 separate 200w amps
thanks
Shawn
91 RS 5.0 TBI
1 Post
Car: 91 Red Sled
What happens when you don't connect the wire to anything? Does the car start? Check the fuse that is next to the battery. You might have blow that. Tell us what is working and was isn't. Also tell me what color, size, fuseable link?, where does the wire go etc. Give us as much info as possible.
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
, Jon (350 TBI!)
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
when i dont attach the wire it doesnt start either.. when i ground this wire the fan works and if it isnt grounded the fan doesnt work i couldnt find the fuse for the fuel pump or at least i dont think i did i found a fuse next to the battery and that fuse is fine... but i thought it was for my alarm.. i'll have to check the car out in the mourning again... how much does a relay cost me if in fact it turns out to be that.. i think it has to do with either my fuel pump relay or my fuel pump fuse if i can find it... any advice?
Shawn
Shawn
the wire i found loose or might of been broke loose is green and white in my haynes manual it says that goes to the fuel pu relay drive? where the hell am i supposed to put this one wire?
Shawn
HELP
Shawn
HELP
Car: 88 IROC
Transmission: auto
The relays shouldn't be more then $10.
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 195ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops,slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Pat Hirsz
88 305TBI
damnet the car borke on friday NIGHT i want to go out and get some booty now i am driving around with my friend in his f*cking sentra...i took the car to the shop cause i dont got the time and time is money so i need it running they should have it done by tomorrow. i changed the relay and still nothing so now i am waiting to see what is broken on the damn camaro now.. you know i know someone selling a 300zx twin turbo (after market tubos) and i am real tempted to sell my car to my mom and buy the nissan... but i love my car ..
Shawn more money in the car...
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
