454 TBI Unit Bolting to 350 TBI Manifold?
Old 03-31-2001, 06:01 PM
killerRF's Avatar
Is this true? A person can just simply bolt on a 454 TBI on a 350 TBI intake manifold and all will be well?
Old 03-31-2001, 06:23 PM
SCRA rules!'s Avatar
The bolt pattern is the same, so it will bolt right up. The problem is the 454 has 2" bores, where as the small block units have 1 11/16" bores. The butterflies won't even open without hitting the top of the intake if you put a 454 unit on a small block tbi intake. Besides, this size difference creates a new restriction, so you don't gain anything anyway from the bigger tbi bores.
I'm sure you can just bore out the intake bores to 2" and be ok. Probably someone here has done it this way. Also, I think the early versions of the Edelbrock tbi intakes for small blocks came with 2" bores. Holley also makes one, but not sure of the bore size. Or you can just use a carb intake with a Holley 1741 adapter plate.
'93 2wd truck
408 sb, vortecs, 454 TBI, Comp Cam, dual exhaust
Old 03-31-2001, 08:24 PM
Tas
Tas's Avatar
you can bore the stock TBI intake out. Ghosst did it. You can't bore out the Edelbrock TBI intake, the walls are too thin.
-Tas
'89 Formula WS-6
[soon to have Hooker 1-5/8" 50 state legal headers installed]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
92camaroJoe
07-29-2023 07:57 PM
MustangBeater20
10-29-2022 09:20 PM
xkingcodex
02-12-2020 07:43 PM
92camaroJoe
08-13-2015 06:07 AM
cRoe4
08-07-2015 08:46 PM
Quick Reply: 454 TBI Unit Bolting to 350 TBI Manifold?
