injector pulse
Car: 89 Camaro, 00Xtreme s-10, 89 Buick "Party Ave"
Engine: 305tbi
Transmission: 700r
injector pulse
Hi all, so I'm still working on my 89 305 tbi. and when I start it...It will start...and keep running....IF...I keep reving on it(pumping the gas) then and only then will the injectors spray...it won't idle...cause if i stop reving they stop pulsing and the engine dies.....now on to my car....I had done a v6-v8 swap on this car...and had to swap harnessed/computer(I had to splice(solder/heat shrink the wires at driverside fire wall)....I later found out the other car(donar car) had vats...well when I swaped the harnesses...since my other car did'nt have vats the starter worked fine... and the ign. coil has great spark....the only hang up is idle.....could this be a vats problem if I can still get the injectors to pules by reving it...or is it something else....I rebuilt the distributer...and ohmed out all the wires(checked good) so can anyone help??
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Possibly. Id have to check, but there may still be accel enrich, which when you pump the throttle would cause the computer to give a momentary shot of fuel. If the current ECM has VATS, then you need to reprogram the PROM to disable it before proceeding any farther.
Car: 88 Camaro SC
Engine: SFI'd 350
www.moates.net. ~$120 dollars and you can burn the prom yourself and not only disable VATS, but tweak the performance as well. Well worth it for future mods.
Engine: 305tbi
Transmission: 700r
on their websight theres one for $85..can I use my p.c. for this....does it include software...or is theat where $120 is totaled up
if I knew this was my problem I'd do it...but I'm still trying to trouble shoot the car without spending alot of money...darn that vats....if i can't figure this out I may have to switch to carb. I just don't have the money to loose if it doesn't fix the prob.
Engine: 305tbi
Transmission: 700r
ok, thanks to a guy posting a homade square wave generator vats schematic....my car is up and running...link...http://temp.corvetteforum.net/c3/70lt1/vats.shtml
the only thing is its idling a little high(2,000 rpm) how do I adjust the idle???
