Smog pump delete info needed
Old 10-19-2015, 03:51 PM
  #51
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: Smog pump delete info needed
Originally Posted by Sir ian
Does anybody know What can i plug the manifold and everything else with so I don't have an exhaust leak when I remove the smog pump and put a shorter belt on?
You can get plugs for the manifold & lowe's, home depot, ace hardware, ect. The plugs are NPT pipe thread if I remember correctly, just bring one of the old fittings for comparison.
Old 10-19-2015, 04:40 PM
  #52
Schurkey's Avatar
Unlikely. Look at the tubes and tube nuts that come OUT of the exhaust manifold--and the threaded holes in the manifold. I bet they're inverted-flare fittings, not pipe thread.
Old 10-19-2015, 05:07 PM
  #53
They could very well be inverted-flare fittings. I know I bought mine at the hardware store in the plumbing dept, which is why I assumed NPT. All I know is they fit & I haven't had any issues with them in the 4 years or so they've been in there. I'm not saying I'm right, I'm saying this is what I did and it worked.
NOTE: Until the plugs are seated you will have to re-tighten them every heat cycle or two.
Old 02-08-2016, 02:51 PM
  #54
RsJerry's Avatar
I'm pretty sure that a 91 is still OBD1 , so you have a read only computer so it can't be flashed or overwritten . Some things can be bypassed , like EGR codes on my 88 RS i fixed by putting a ball bearing in the vacuum line just before it goes into the EGR valve , this works because the code was tripped by a vacuum signal that only reads if there is a leak in the line or in the valve itself , for that system no news is good news so blocking the signal was all it took .
Old 03-09-2018, 11:21 PM
  #55
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
Anyone know an easier way to remove those damn AIR tubes from the manifolds??
Old 03-10-2018, 01:28 AM
  #56
Drew's Avatar
Received 1,052 Likes on 748 Posts
Cut the tube off flush at the nut, weld the hole closed. Done.
Old 03-12-2018, 11:22 PM
  #57
Jake_92RS's Avatar
How do you get the AIR tube from the catalytic converter out of the engine bay?
Old 03-13-2018, 08:10 AM
  #58
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I think it is bolted to the back of the heads
Old 03-13-2018, 12:30 PM
  #59
Schurkey's Avatar
If some of you need that much help to gut your emissions system...maybe you should reconsider WHY you feel the need to gut your system.
Old 03-15-2018, 10:37 PM
  #60
Jake_92RS's Avatar
I got mine out no problem, just nice to have some insight on easier ways to remove it. Taking it out isn't about adding HP for me, its about allowing for easier maintenance, maybe exhaust upgrades, and an overall cleaner engine bay.
Old 09-15-2023, 03:07 PM
  #61
newvetowner's Avatar
Is anyone able to tell me, if I delete the smog air pump and use the delete pulley, will this affect the ERG codes? I have two current issues, one is that a baring in my smog air pump is gone and I can't find a replacement part for the life of me so I think my only option is to remove it and use the delete pulley. My second is I'm getting code 32 ERG so I'm not sure if its because the smog pump isn't working properly or if its something else. The car is difficult to start, taking 2-3 turns but once it does, it runs beautifully with the exception of the squeal from the smog pump and code 32 / SES flashing. I'm pretty new to this and trying to figure it all out. This is for the 1988 corvette. Thank you in advance.
Old 09-16-2023, 11:25 PM
  #62
Schurkey's Avatar
Get an AIR pump from the Treasure Yard, and fix the EGR code. The two things are almost certainly NOT related.
newvetowner (09-17-2023)
Frozer!!!
01-19-2024 04:55 PM
italiano67
12-11-2016 09:21 AM
IROCZ1989
01-24-2016 03:55 PM
86camaroman201
Fabrication
08-11-2015 10:39 PM
GEmrsn
Interior Parts Wanted
08-08-2015 03:15 PM
Quick Reply: Smog pump delete info needed
