WHats the difference between TBI and TPI and which is better? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 07-12-2001, 11:47 AM   #1
Whats the difference between TBI and TPI and which is better? I have a 305 TBI 89 RS Camaro. I don't have any understanding of the two.
[This message has been edited by un4givin89 (edited July 12, 2001).]
un4givin89 is offline vBGarage Page   Reply With Quote
Old 07-12-2001, 11:53 AM   #2
there is an explanation on the site in the FAQ section.
TBI=Throttle Body Injection
TPI=Tuned Port Injection
carter89RS is offline vBGarage Page   Reply With Quote
Old 07-12-2001, 01:49 PM   #3
Oh GOd Don't start the which is better.
They both have their good and Bad points. TPI is faster out of the box, but its more expensive to tune and Build with, but can also be faster in the end because of the Ability to "Tune" the engine with a better computer and dry flow system. Where as the TBI is cheaper, easier to learn and deal with, but les tuning capabilities.
All in what you want to do with it.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Kyle F is offline vBGarage Page   Reply With Quote
Old 07-12-2001, 02:21 PM   #4
Car: 91 Red Sled
Kyle is right in some instances but the ecm is not a problem. Both ecms run the same, TBI is speed density and TPI can be either MAF or SD. The data line might have a different rate/speed but that isn't the speed of the actual mechanics. The TBI ecm is just as fast internally as any TPI ecm, both react instantly to TPS changes or you would have a good .5 second delay in throttle responce with TBI (which we don't). Just look at all the really expensive race EFI setups. They have less options than even the TBI ecms! Mostly because they aren't built for all around, not too many race cars looking for good gas milage (NASCAR but not efi!).
If you search for TPI and TBI in the archives you should look at the large topics (30+ replies). At one point I had a HUGE post that shut up a lot of the TPI die hards from bashing TBI. The real difference is this: Wet flow vs. dry flow
Both are efi but the TBI has some advantages common to the carb but at the same time has some of it's flaws. TBI is a cross between carb and TPI, it gives you a great EFI system that runs like a carb but with most of the advantages of EFI. A cross bread so to speak.
, Jon (350 TBI!)
91 Red My website
JPrevost is offline vBGarage Page   Reply With Quote
Old 07-12-2001, 08:14 PM   #5
Thanks guys, just curious. I have TBI and and the only thing I knew about them was the way the engines looked. But if TBI is cheaper sounds up my alley and something I'll most likely stick with.
Thread Thread Starter Forum Replies Last Post
1992 camaro 305 v8 TBI idles very high and shifts at high idles db057 TBI 11 06-07-2016 09:26 PM
TPI Compatability masonta TPI 13 08-31-2015 11:14 PM
400 HSR Serpentine setup - What did I do wrong? evilstuie Tech / General Engine 18 08-24-2015 10:20 PM
[QC] 1990 TPI & T5 Engine Harness, PCM & PROM Sanjay Engine/Drivetrain/Suspension Parts for Sale 1 08-12-2015 04:41 PM
Some questions about TBI.. MustangBeater20 TBI 0 08-05-2015 10:49 PM
Go Back   Third Generation F-Body Message Boards >
Tags
305, 350, body, carb, difference, efi, heads, injection, motor, mpi, ported, tbi, throttle, tpi, tuned, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
