95 or 95 TA Cam???
Old 08-26-2008, 04:51 PM
dctrumpet's Avatar
Car: 1992 Firebird
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
95 or 96 LT1 Cam???
Which is overall the best cam? A 1995 stock LT1 or 1996 stock LT1 cam? I am upgrading from a stock 5.7L tbi cam.
I am installing Comp Cams 1418-16 roller rockers (1.6) with RHS heads with 2.02/1.60 valves 76cc chamber. 50mm ported edelbrock performer tbi intake with a 7.4L tbi base and cop car injectors (4327). 255pph fuel pump and afpr.
Need to know what the best cam is of the two that I have. I have looked at the following info on the LT1 cam threads, but not sure what to do. Help? Please? I have spent a few hours reading and now it's time to ask for help.
Thanks so much guys!!!
http://www.malcams.com/legacy/misc/CamData.htm
Old 08-26-2008, 04:57 PM
dctrumpet's Avatar
Car: 1992 Firebird
Re: 95 or 95 TA Cam???
Unfortunately, there is no part number on either cam. Only numbers stamped are the following:
1995 TA Cam GMPT BC 13 241
1996 TA Cam GMPT BC 15 705
Old 08-26-2008, 06:05 PM
dctrumpet's Avatar
Car: 1992 Firebird
Any ideas?
Old 08-26-2008, 07:58 PM
dctrumpet's Avatar
Car: 1992 Firebird
Any suggestions guys?
Old 08-26-2008, 09:44 PM
dctrumpet's Avatar
Car: 1992 Firebird
Seems that I find 4 different "spec" charts for 94-96 LT1 cams. They "supposedly" were all the same. Who's right? LOL!!!
HELP!!!
Simple, I just want to know if the specs are the same between the 95 and 9 LT1 cams and if anyone "really" knows what they are.
Old 08-26-2008, 10:02 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
93-95 LT1 202/207 @ 0.050" .450"/.460" Lift, LSA 116
96 LT1 200/207 @ 0.050" .447"/.459" LSA 117
You would be slightly better off with the 95 cam, For what you are doing I would go bigger than either of those.
Old 08-26-2008, 10:13 PM
dctrumpet's Avatar
Car: 1992 Firebird
What would you recommend?
I know that either of the LT1 cams are a lot better than my stock 350 TBI cam. I want something easily tuneable, but something to match my intake, fuel system and heads.
Comp Cams??? Which one?
Old 08-26-2008, 11:55 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Maybe a LT4 hotcam?
Try using the comp cams cam quest. Just google it, they made it free not to long ago and it rocks : )
itll help you, trust me
Old 08-27-2008, 04:50 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
LT1 cam's are easy for stock LO3's, since they do not require many modifications.
How much lift can LO5 take?
Old 08-28-2008, 10:00 PM
dctrumpet's Avatar
Car: 1992 Firebird
Well, I bit the bullet, lol!!! Just purchased a Comp Cams 8-304-8. The cam, heads and other mods should bring a strong 350hp!!! YES!!!
The 1.6 rockers should bring my lift close to .544
Will let you know when it's done.
Thanks everyone for your help!
Old 08-30-2008, 08:49 AM
dctrumpet's Avatar
Car: 1992 Firebird
I believe stock 193 heads can handle .480 MAX lift. It is safe to go with .475
That is my understanding.
Prodigious
Theoretical and Street Racing
35
04-13-2021 02:37 PM
Jorlain
10-08-2015 01:57 AM
customblackbird
10-01-2015 04:30 PM
Strick1
09-04-2015 07:11 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: 95 or 95 TA Cam???
