Camshaft Question
Old 08-30-2008, 09:47 AM
CaddyMan's Avatar
Car: 1990 Cadillac Fleetwood Brougham
Engine: Chevy 350 TBI with some goodies
Transmission: TH-7OO-R4, waiting for rebuild
Axle/Gears: Stock. Saving for 3.73 posi unit.
Camshaft Question
I currently have a CRANE Camshaft with my Vortec heads. I was looking at the LT4 Hotcam. The numbers look pretty good. Has anyone here tried this set-up before? (Vortec heads & HotCam) I am going to be purchasing the computer upgrade kit from RBob's company. I was looking to get a little more power from my set up. Any suggestions would be appreciated.
My current cam specs are 204/214 & .429/.452
Old 08-31-2008, 12:35 PM
CaddyMan's Avatar
Re: Camshaft Question
Anyone?? I just need a second opinion before I buy one.
Old 09-08-2008, 10:42 AM
CaddyMan's Avatar
Is it because I have a Cadillac? I did some research and decided not to get the HotCam. Thanks
Old 09-08-2008, 11:07 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I don't know if you got anything yet, but it depends on what you're looking for the car to do. The cam you have I would call a stock replacement/slight upgrade. The hotcam is still a small street cam with 218 intake duration, but would likely give you a decent bit more power. For something street/strip, I'd tend toward something upper 220's intake duration or even low 230's. The more you go, the more power it will make, but the less streetable it will be and more converter/gear/rpm it will want.
Old 09-08-2008, 11:31 AM
CaddyMan's Avatar
Thank you for the reply. I decided not to get the cam, but now I am back to being undecided. My engines redlines at around 5500, so anything over 230 intake wouldnt be that good. Plus I want to maintain my vacuum for my brakes. What would be an ideal cam for a 5500lb car while maintaining streetability. Keep in mind that I plan on purchasing the EBL, so I am ready to tune.
blackroc68
09-01-2015 08:01 PM
midge54
08-29-2015 09:51 PM
SLNTSCPE
08-22-2015 09:15 PM
Jake_92RS
08-17-2015 09:42 AM
redmaroz
08-16-2015 11:40 PM
Quick Reply: Camshaft Question
