TPS Sensor question
Old 10-25-2008, 01:28 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
TPS Sensor question
Okay, so im getting an intermittent code while driving. Usually happens when slowing down at a light or something. Idle kicks up way high and a throw the SES light. The code goes away when i accelerate, usually within 30 seconds. While the SES light is on the idle is choppy and bounces around between like 1500 and 2200 rpms. I cant get the code number because the code doesnt seem to store and it never happens while im just parked somewhere. Does this sound like a TPS sensor problem?
Old 10-25-2008, 04:58 PM
kcb37's Avatar
Re: TPS Sensor question
Wouldn't hurt to check it.
You could also clean the IAC too.
Old 10-25-2008, 06:43 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
I vote IAC. Could have a bad connection or could b dirty. When I unplugged my IAC the Idle would shoot way higher than normal then settle once I plugged it back in.
Old 10-26-2008, 07:33 AM
kcb37's Avatar
Helped stabilize the idle on my car when I cleaned mine.
Old 10-26-2008, 01:34 PM
Saber's Avatar
I just recently cleaned the IAC when i swapped in my new injectors, guess it wouldnt hurt to clean it again. Also how would you check the TPS? There has to be some way to tell if its going bad.
Old 10-27-2008, 06:44 PM
Saber's Avatar
So i finally got the code to stay on, its throwing a code 22, i searched and found out that means low voltage to the TPS? It was for a TPI car thought and not a TBI car, is the code the same regardless?
Old 10-27-2008, 08:55 PM
sweetaq's Avatar
Car: 1982 Z28
Yep I got the same code when my TPS was not adjusted properly. There is a tech article on how to adjust it properly.
bamaboy0323
09-03-2015 06:07 AM
redmaroz
08-16-2015 11:40 PM
mdtoren
08-16-2015 05:45 PM
fonzie85
08-13-2015 11:50 AM
Quick Reply: TPS Sensor question
