What's the best way to clean gunk out of my engine
Old 06-05-2009, 07:38 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
My 83 Camaro Cross-Fire has 165000 miles. Theres alot of gum and varnish in the engine just from what I can see through the valve covers. Whats the best additive for this. I want something for the gas too. I change my oil regularly and it aint helping. Id rather not use seafoam because it makes way too much smoke when you first start it after pouring it throughout the car. I accually heard z max doesn't work either. Please help
Old 06-05-2009, 08:46 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: What's the best way to clean gunk out of my engine
Look up a product called " Sea foam" or do a search for Sea Foam on this bord.
http://www.seafoamsales.com/
Old 06-05-2009, 10:13 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
he just said he didnt want to use seafoam.
its really hard to get the inside of your engine clean without taking it all apart. id say seafoam is a good bet, you dont have to use it through a vacuum hose like you see, you can actually just pour it into your oil before your doing an oil change, and run it for alittle while with it in there, then rain it all out. i myself have never done that, i just dont feel that good about letting some random liquid floating around with my oil. but anyways you can either put it in your oil, or your gas, or through a vacuum hose.
Old 06-05-2009, 10:18 PM
duderjay's Avatar
Car: 88 iroc z28
Once a year on the saturn I use a liter of auto trans fluid for a 100 km to 200 km in the engine oil during regular driving. It has lots of detergents in it..... But by far the best I have used is full syn oil for a few months and then just switched back to regular oil and it helped enormously.
The Camaro I recently put in full syn and never had any issues before with gunk or varnish
Old 06-06-2009, 08:43 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
ATF Works great! Cheap, too.
Infested
05-22-2018 11:56 PM
TheExaminer
08-26-2015 04:59 PM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: What's the best way to clean gunk out of my engine
