whats the difference between AMUL and ANLU
Car: 89 RS, 93 Z28
Engine: Vortec 350 TBI, Lt1 6 Speed
I did a search but didn't find much information about the AMUL chip. I recently acquired a AMUL chip from a 1990 Caprice with a 350 TBI engine for a 8746 ECM and was wondering what the difference between this chip and the popular ANLU chip was. Is it just the speed limiter is on the AMUL chip or something else all together?
Car: 89 RS, 93 Z28
Re: whats the difference between AMUL and ANLU
Everything I have read says it came from a L05 with "7" in the VIN and 8746 ECM and came in 89 and 90 caprice's with TBI. I know it was in a 8746 ECM because I pulled it out myself since I didn't need another ECM because I already have two 8746 ECM's
This is a CP from one site
1228746
Schematic
Application:1989-90 5.0 V8 TBI “E” L03
1991-92 5.0 V8 TBI “E” L03 (“F” body)
1989-90 5.7 V8 TBI “7” L05MEMPAK IDs:“E”: APFN, AXKS, …
“7”: ANLU, AUML, …
CALPAK IDs:16060837
Program ID:97 ($61)
Pgm ID Addr:$D004
Scan ID Addr:$D002:$D003
EPROM type:2732
EPROM offset:$D000
1228746
Schematic
“7”: ANLU, AUML, …
CALPAK IDs:16060837
Program ID:97 ($61)
Pgm ID Addr:$D004
EPROM type:2732
EPROM offset:$D000
I've gotten two ANLU ECUs out of '89 and '90 Caprices. One was a cop car ('90) and the other was a civi ('89). Both were 5.0L w/ TH200-4R
Car: 89 RS, 93 Z28
Car: 89 RS, 93 Z28
You are correct! sometimes my fingers do not want to work along with my brain since I do the hunt and peck type of typing. I am sorry for the confusion. it is the AUML. now that we all know what I am talking about, can anyone tell me the difference lol
Car: 89 RS, 93 Z28
is there any difference? I looked on here and from what I could tell the speed limiter is the same on both chips https://www.thirdgen.org/forums/tbi/...code-real.html so I am guessing they are both are at least close but I am sure there has to be a difference somewhere to have different part numbers. Maybe fed/cali emissions thing?
well, if you are at all computer savvy, I would download the $61 dis from moates, and find a hex compare program. Then compare the ANLU and AUML bins. you can then look at the locations in the disassembly to see the differences. Be warned that it will be time consuming. I just got done editing a $0D asm file to match the bin I wanted and it took me a month working 2-3 hrs a night. On the other hand, you end up knowing the code fairly well. If you don't understand code, the easier thing to do would be to use TUNERPRO RT and load the correct XDF. Then load each bin and go thru all the tables and constants to see the differences. It is also time consuming, but a lot easier for a non-programmer to understand
Car: 89 RS, 93 Z28
Car: check
Engine: check
Transmission: check
The ANLU calibration is for the 1989 MY. And the AUML calibration is for the 1990 MY. Most likely the differences are for emissions purposes. As the years went on emissions got tighter.
RBob.
Car: 1983 G20 Chevy
Transmission: 4L60
There is a difference tool built into TunerPro. Read ANLU in, then set up AUML as a compare BIN. Then use the difference tool to show the differences between the cals.
RBob.
RBob.
Car: 89 RS, 93 Z28
Thanks for the information. RBob I am sorry again for the typo and the confusion it caused
Sorry guys, I should have checked my notebook. ANLU IS the 5.7L from the cop car. The 5.0L one I am talking about above is APFN... Hopefully didn't cause to much confusion.
