Slow/Hard Starts When Cold, Starts Fine When Warmed Up
Old 10-11-2010, 07:56 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
Crisper Cold Starts
My car starts fine an runs really well.
But when I start it cold it takes a second or so before it starts. I might sound like I'm nit picking here, but is there any way to make the car start smoother?
Old 10-11-2010, 08:09 PM
mog10's Avatar
Re: Slow/Hard Starts When Cold, Starts Fine When Warmed Up
your oil could be to thick what are you using
Old 10-11-2010, 08:22 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
It's been awhile since I changed the oil (I hardly ever drive the car), so I can't remember what viscosity I used. I know it's Mobil One synthetic, probably your standard 10w-30.
I live in Southern California, so the weather is very mild. It's been between 60-80 degrees around here.
What's strange, is that it will never start on the 1st attempt when cold, but will start relatively easy on the 2nd attempt when cold. But it still starts slow.
Old 10-11-2010, 08:24 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
same problem with tpi, cant figure it out either, I always seem to have weird problems, wher everything thats a cause is not the cause,
Old 10-12-2010, 04:17 AM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Im no expert but could it be a fuel issue ? Do you let the pump prime before you start your car , u know let the little beep thing go away before you crank it, maybe when its cold fuel is not getting to the cylinders on the first try, dunnon bad fuel preassure regulator ? Again im no expert but this could be fuel related , if you have spark and air getting to those cylinders i dont see why it will not start with fuel also getting to them also. Could be your idle control valve , the little motor could be bad and it takes some time to open up, take it off and see if its not cloged, have u tried starting the car with the throttle manually open, if it does start then u ur iac could be messed up.
TBI is kinda of like a carb, the fuel has to travel all the way from the top to the cylinders so TBI takes a little more cranks than ur conventional efi motor with the injectors closer to the valves, well atleast thats how my TBI bird starts up, my brother lt1 and l98 used to start to the touch of the key, i mean instantly lol.
Old 02-22-2011, 11:18 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I know this an old thread, but I found out what the problem was.
It was just old gas. That's it. I don't drive it that often, so the gas in it was over a year old. Once I burned it all off and put new fuel in it, it started just fine.
jklein337
09-19-2018 06:23 PM
Wade787b
09-29-2015 01:15 PM
Bryan F
08-18-2015 02:28 PM
mustangman65_79
08-08-2015 12:07 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Slow/Hard Starts When Cold, Starts Fine When Warmed Up
