Finished swap,Hello 5.7=]
Old 04-02-2011, 04:08 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Just finished our 305-350 swap in my 88 Trans am. Yes there was large sums of cussing,and also a lot of anger and bullcrap involved. But were finally finished=] Just a few things here and there. New rad fan switch,spark plug heat wrap,nothin bad at all. We also need to get the new ypipe fitted to the Catalytic converter.
The engine is a 350 l05 TBI out of a 93 Buick Roadmaster. It was owned by an old lady so she took real good care of it. Got it cleaned up and painted,replaced some parts, put some headers on,rockers,the usual.
We were pretty nervous at first. But FIRST TRY the engine cranked about 3 times and fired right up! sounds like a beast. Runs really well and im very happy with the result. There were some things that caused a few roadblocks on the way. Needed a new TBI chip to work with the new motor,new sensors,had to remove some of the unused sensors on the motor,and for some reason the Roadmaster motor had a Mechanical oil pressure unit? So we had to replace that also. New gasline, vacuum lines,transmission lines, swapped the positive and negative lines to front mount( the PO had the lines for top mount) New water pump,oil pump,Rad lines, brake booster line, power steering pump,and we rebuild the throttle body. We also got a new fuel sending unit because the old one rusted away. New starter,solenoid, High performance Taylor spark plugs,MSD distributor cap,chrome valve covers, and swapped the r12 to r134. And cant forget the Open Element air breather! Bought the Spectre Speed open element at auto zone for 70 bucks,and a 1 1/2 inch spacer. it fit without the distributor in,but after all was said and done,it sat up to high. So were picking up a 10" Edelbrock one tomorrow. Heres some pics.
The video does not do justice at all. This was the first startup. We fired her up today and she didnt even crank once,she fired up as soon as you turned the key. It shakes the ground and when you rev her it shakes the whole car. God im so glad i didnt rebuild that 305.
http://www.facebook.com/v/210485182295925
Old 04-02-2011, 01:29 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Re: Finished swap,Hello 5.7=]
Sweet!
Old 04-02-2011, 09:26 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
good job man. glad you got her going...any plans for a racetrack adventure?
Old 04-11-2011, 01:25 PM
Dougie91's Avatar
Car: 1992 Firebird convertible
Engine: 5.0 tbi
Axle/Gears: stock, slow and steady 2.73's
So what it cost in total? and what hp you lookin at? take a long time? im really interested in doing this!
Old 04-11-2011, 04:49 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
The L05s have around 210-220hp / 320-330lb tq stock.
Old 04-11-2011, 08:35 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
If your doing a same for same swap it'll take you a weekend. but now if your swapping engines and some parts, plus adding headers, etc...then maybe 2 weekends.
Old 04-11-2011, 10:20 PM
yes what the last two said. the type A motor has an average of 190-220. The type H has about 230-260? Somewhere in there. ANd if you got time itll take a weekend
Old 04-11-2011, 11:30 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah I was making the reply to average do it yourselfer. Itd take me a day if all parts were cleaned and straight trade out with first fireup and run/break in time etc.
Old 04-23-2011, 01:25 AM
Dougie91's Avatar
Engine: 5.0 tbi
are l05s just as much as a pain with chip tuning?
Old 04-23-2011, 02:12 AM
Not at all,i ordered mine from a guy in illinois for about 150 bucks. I had to though because my car is a 1988 and that was the only year they made with a special VATS system
Old 04-24-2011, 07:32 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Civilian B-car L05 had 180 HP and 300 ft/lbs....Blame that on the tiny little L03 roller cam that was in them.
Frozer!!!
01-19-2024 04:55 PM
ZMWojnar
Brakes
05-12-2019 10:43 PM
pimprs
08-24-2015 11:20 PM
InfinityShade
08-22-2015 08:00 PM
jharrison5
08-19-2015 05:53 PM
Quick Reply: Finished swap,Hello 5.7=]
