serpentine belt size with power steering pump removed
I cannot find the belt length for my serpentine belt if the power steering pump is removed. Can somebody please list the belt length or part number? In the technical article it lists the part number for the belt without the A.I.R pump removed as a Dayco 968K6, but it shows a picture of a accessory drive without the power steering pump. Thanks, George.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: serpentine belt size with power steering pump removed
What I tend to do. Is take a piece of string and run it around all the pulleys. then measure that. Take that # to your parts store and they'll get you your belt
Engine: gone
Transmission: gone
Axle/Gears: gone
Yes so for instance if you get 98.5 inches. you'd need belt # XXX985 or whatever belt manufactuer your going with I think in gates its like a K060985. If its 94.3 It'd be K060943 (should be) but they may not make that. So you may have to go k060945...
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
knight72
08-10-2015 09:32 PM
