Car wont idle at all
Old 11-05-2012, 12:25 AM
Camaroguyrs91's Avatar
I have a 1991 camaro rs with the 305 and i have replaced several parts thinking that they are the problems, such as TPS, ECM, distributor, wires, plugs, cap, rotor, rebuilt the tbi, and probably even more just cant think off the top of my head. The car wont spray the fuel in order to idle, i can keep the car running by pumping the throttle but i cant just lay my foot into it and have it increase rpm, it will just bog out and die but it will spray the fuel. I need this car on the road soon so hopefully somebody will have some good answers.
Old 11-05-2012, 06:05 AM
ex-x-fire's Avatar
Re: Car wont idle at all
Sounds like low fuel pressure, auto zone has a tbi fuel pressure tester that you can rent/buy. Spec is 9-13psi.
Old 11-05-2012, 12:02 PM
I put a new fuel pump in it and the pressure is about 13
Old 11-05-2012, 03:48 PM
onebad92's Avatar
what was the initial problem that made you replace all those parts? its acting the exact same way after all the new parts and rebuilding the tbi? no change?
Old 11-05-2012, 06:07 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
did you check your old plugs to see if you blew a head gasket. Also check and clean the iac, check your map sensor.
specialized
06-18-2022 09:26 AM
Spyder_TheGamer
12-25-2015 05:07 PM
Wade787b
09-29-2015 01:15 PM
Armored91Camaro
08-12-2015 09:41 AM
Quick Reply: Car wont idle at all
